Question about Refrigerators
Stopped getting cold on the fridge side and slowly doing the same on the freezer side. Also in the back on the same side of the fridge there is a black canister and that was also extremely hot?
  • Refrigerators Master
  • 43,501 Answers
Your compressor is very hot and probably is not starting...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Whirlpool 6ED2FHKXRL side-by-side fridge/freezer not cooling properly
Is there a lot of ice in the bottom of the freezer, at the back? If so, you will need to get the ice out as it is probably blocking the door passage from the freezer to the fridge.
Dec 04, 2013 | Refrigerators
Fridge freezer not cooling
if its cooling but the fridge side is too cold then the damper door that control the cold air from the freezer to the fridge side is stuck open and not closing when the fridge is no longer calling for cold air
Jan 31, 2013 | Refrigerators
Hello, I have a Maytag side by side fridge that is 26 cu. ft. The freezer has stopped working and the fridge is slowly getting warmer. I have tried unplugging it and plugging it back in. This has not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jul 06, 2011 | Maytag Freezers
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Fridge not staying cold
Inside the fresh food compartment there is a defrost timer hidden behind the temp control panel. Sometimes there is a plastic plug over the hole that you need to put a flathead screwdriver in and slowly turn it clockwise. When compressor stops I want you to wait about 25 minutes to see if the refrigerator comes back on by itself without help. If it does I need you to listen inside the freezer compartment for sa sound of crackling or sizzling noise indicating defrost is taking place. Let me know, Sea Breeze
May 19, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
