Question about Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
Unplugged speakers form computer to move house .Can't remember where to plug them in to the computer?
  • 66 Answers
I the bottom of the cpu
Posted on Oct 02, 2010
  • Ben Armstrong Jan 16, 2011
    The above information is incorrect. Plugging into the CPU would A) Be impossible and (B) mean oppening up the chasis! For Your info Tamilazha789, the CPU is the Central Proccessing Unit. the main "brain" of the computer. The two most common types being Intel or AMD. What you are thinking of is the motherboard.
    The correct advice for this is as follows : Identify what computer you have. Is It A Mac or PC?
    If it is PC
    There should be 2 small 3.5mm coloured sockets on the back,front (or both ) of the main box (tower/desktop unit). You should find that they are coloured Green and Red. Green is for sound output (Headphones/speakers or hifi) and the Red is for sound input or Recording. Used for things like microphones. Some will accept line sources such as mixers and Ipods pr cassette players, but please check your sound manager, mixer settings in your opperating system to make your you have an adjustable input setting for Mic and Line input attenuation as not all do and you may end up with a distorted mess.
    You may also find there is a small diagram of headphones or a microphone to indicate sound "in" and "out" ports.
    If you have a mac
    Appart fom me being envious :-) there are two sockets. On laptop types, on the side or on the tower types on the front,back or bothe. They have a diagram of a microphone and headphones. Hadphones is for audio output to headphones, speakers, hifi, dj mixer. The Microphone is a sound input. Please read above for microphone port usage.
    Hopefully this answers your question. Please also bear in mind that if you have no sound once plugged in, you may need to adjust the audio properties in the system in the system and/or program you may be using.
I unplugged my it188b speaker from my pc yesterday. When I plugged it back in, it wouldn't play, the pc speakers play instead. How do I turn off the pc speakers and get my sound bar to play again?
Check your computer set up. It might have switched the speakers off when you unplugged it. If that doesn't work it could be the jack plug itself. But often you can tell it's faulty due to if it's moved it might come back on again.
Sep 09, 2017 | The Computers & Internet
Lost my sound when I moved my computer
Have you checked speakers on another computer. Get it checked first if it working on another computer or other device. If it working reinstall realteK audio drivers.
Nov 04, 2017 | eMachines ET1810-01 PC Desktop
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
I just brought this computer to my house from my girl friends grandmas house speakers and all worked fine now i plugged everything in the the exact speakers that were on it are plugged into it and the...
Assuming something in the computer didn't mysteriously go bad during the move, there are two possibilities. First, make sure the signal cable from the speakers is plugged in to the right place. You may have plugged it into the microphone input or line input jack by mistake. Second, be sure the speakers have power. Most speaker systems require AC power, either from a plug-in adapter or a built-in supply that needs an AC connection. (Some newer systems come with USB-powered speakers that don't need an external adapter.)
A remote possibility is that in the move, the speakers got bumped enough to disturb connections on the circuit board inside. The amplifier chip in the speaker case gets hot (especially if the volume is turned way up), and the heat can degrade solder connections, and sometimes cracks form. The move may have caused connections that were iffy to go bad. But this isn't very likely.
You'll probably find it to be a very simple missed connection. Good luck, and thanks for using Fixya!
Oct 24, 2010 | Dell P4 2.8 GHz (DELLDIMREF1100) PC...
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right side...no sound
speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Aug 24, 2010 | HP JBL Platinum Computer Speakers
No sound
go to logitech website put in model bring up info on it ok;
May 02, 2010 | Logitech X-530 Computer Speakers
No sound
make sure the speakers are plugged into the GREEN port on your sound card many times people plug it into the linei n or mic jack by accident.
Dec 30, 2008 | Logitech X-240 Computer Speakers
My computer speakers are making this weird noise
the First thing to test are the speakers form a different source. I believe that if you hook them up to another computer or an mp3 player you will find that the problem goes away and they work fine. (I know this by the info you gave me. THe fact that you get a large hum from the card when it is plugged in means that the output on the card has a short in it and is crossing the connections somewhere.
Solution is to have the card replaced or test it with another set of speakers just to be sure it isn't the cable.
Dec 14, 2008 | Dell A215 Computer Speakers
Connecting computer speakers
HI SSSNAP
Happy Holidays
Well, you have to : depending on the model of your Sound Card, I presume SBlive? or Audigy models, refer to the manual, but, you have too, depending on the speakers model, place the cables according (ussualy) for the colors. green , black, orange on the respective places. test as you move the cables.
good Luck
Nov 20, 2007 | Logitech Z-5500 Computer Speakers
Bose Companion 2 Series II Multimedia Speaker System (2-Piece) Logo
42 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
