Question about Sony Playstation 3 (PS3) Console
Connections? Please help. I have a portable broadband usb modem wich works perfectly with my laptop as I am using it now but it just seems to not work in my son's playstation 3, Can I make this work at all and how? Man thanks
    Champion:
  • 207 Answers
Ok I had this issue with one of mine as well try this out first and if it does not work Ill give you some other things to try.
1. shut off and/or unplug everything.
2. plug the wireless adapter into the ps3
3. turn on the router
4. turn on the ps3
I had to do this with my alienware laptop and my ps3, it worked for 9 of the 12 ps3's I have had this issue with.
Posted on May 27, 2008
Acer5536 laptop will not connect to the internet wireless will connect by ethernet cable why
you might have a modem with an ethernet connection to connect to the net .
if you have a laptop you can choose a wireless usb broadband modem which can work on a desktop also once you recieve the modem just insert the modem into a usb port and follow the prompts you might need some drivers for the usb broadband modem which can be supplied by the ISP internet provider
hope this helps
Nov 14, 2010 | Acer 91.AB370.001 Network Adapter
I have an external modem for broadband connection. it connects only via usb i am not able to connect via the phone cable port. what seems to be wrong?
The broadband modem connects to thecomputer using the USB or nework port not the phone cable port.
The network port has 8 wire connectors and whilst they both look similar the network (10baseT) port is wider than the phone port.
You also need to configure or reconfigure the model to let it know which cable you are using to connect the modem to the computer.
Apr 05, 2009 | Acer Aspire 1703SC Notebook
How to install zte 831 aii Broadband modem in Linux with USB
I was working at one of Lithuanian internet service providers. We often had clients complaining about ZTE 831 connecting through USB. The answer is - use a LAN card. Sorry.
Mar 13, 2009 | Computers & Internet
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
BSNL Broadband with Windows Vista
To fix the issue in windows vista.Follow the stepss
1.Plug the usb modem 2.goto control panel > windows update. Windows update will find the drivers automatically and will install it..
Dec 27, 2008 | Computers & Internet
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
I have a Toshiba Satellite notebook with Vista Home and NAV 360 and recently purchased a Sierra Wireless Mobile Broadband USB modem T-Stick D597. When I try to install the T-Stick, I keep getting an error...
You might want to disable the WiFi that is built into your laptop before installing that device. It is very possible that the built in WiFi is conflicting with that Wireless Broadband Device.
Aug 16, 2008 | Computers & Internet
Installing Wireless Modem for Wireless Broadband to my Laptop.
Some can use a usb connection or the ethernet connection.
Jan 25, 2008 | Computers & Internet
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Virgin broadband modem
You didnt explain about how you were connecting the desktop and through which....USB or Ethernet. You say you have no problems with the laptop most of us connect the laptop throught the USB port and our desktop through the ethernet the both connected to the modem. All you are having problems with is networking. If you open up the connection adapters looking first at the laptop one and confirming that the TCP/IP protocols are the same or should be. Copy the laptop one and place those protocols in the desktop adapter it must connect. It will complain to you if the address's is the same, use another number.
Sep 14, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
