Question about Samsung LA40R81BDX 40 in. LCD TV
My Samsung LCD TV la40r81bd wont switch on. I have replaced batts in remote. All that happens is that there is a sound (like a popping switching on sound), but no picture or other sound. The bottom power light on the bottom right hand corner is flashing red...I have tried without the remote too. Also tried leaving it off, for hours then reconnecting. While I leave it I can hear the switching on sound intermittently...almost as if it is trying to switch itself on...Was working fine yesterday mrning!
  • raynel Oct 02, 2010
    i DO NOT WANT TO OPEN THE TV...IF THAT IS WHAT IS NCESSARY i WOULD RATHER HAVE A SPECIALIST DO IT...ANY OTHER SUGGESTIONS?
  • Samsung Master
  • 5,807 Answers
If there is a flashing red , it means that the protection circuits
have been activated,
There could be a communication error on the boards or
possible faulty components .
If you feel you can DIY , have the tools and equipment
here are initial things to do:
troubleshooting
you will be checking for Power supply DC outs ( many )
just to insure each have enough to supply to other
stages on the board.
sample image ( not like yours but similar )
center is your sample power supply
Additional guide:
troubleshooting
How to test MOSFET
Transistors
http://www.fixya.com/support/t6177867-great_ideas_fix_samsung_50_plasma
I will post for more should you feel you need
more further assistance or clarifications
Posted on Oct 02, 2010
    President:
  • 1,961 Answers
If you want to DIY this TV you need to open the back cover of your TV 9BE SURE TO UNPLUG THE UNIT BEFORE SERVICING) Examine first the power supply section.using a voltage tester measure the output of it.
5v for the CPU board
12v for the sound amplifier
24 v for the inverter board/backlight.
if one of this voltage is missing then you need to repair first the power supply.measure first this voltages and post a message for further assistance.
  • Danilo Baraquiel
    Danilo Baraquiel Oct 02, 2010
    yes sir! It would be better to bring your TV to the service center because that problem requires a technical knowlege to do it.thank you for using fixya!good day!
Samsung la40r81bd tv
If this is the case, the headphone socket to your TV should be checked. Contact any service technician.
Dec 09, 2013 | Samsung LA40R81BDX 40 in. LCD TV
Samsung le46 lcd tv sound goes down to zero and wont stay up
Under each of the plastic buttons on the set there is a tiny push switch--the plastic button activates it---it is a momentary switch and when the button is released it should stop its function.
A lot do not--fail: vol up is worst but can be any of them. The way to prove this is get at that switch (vol down in your case) which is usually on a small circuit board---unsolder the two pins for that switch and remove it.
If problem gone you know what it was---you really do not have to replace it as the remote should duplicate all functions of these switches---in some cases the remote will not control or stop this---front controls have priority over the remote.
Dec 07, 2012 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Recently i replaced eeproms in lcd's la40r81bd & la40n81bd, i can get into service mode but do not have the data to set it up correctly. can you help with correct data, thanks in anticipation.
Out of curiosity why did you replace the eeproms?
In my opinion only good solution to the problem would be to get an image from a working eeprom and burn it in the replacement.
Manually setting up data sucks.
Sep 25, 2011 | Samsung LA40R81BDX 40 in. LCD TV
My Samsung LCD TV (40A450) 40 inch, when switch turn on after 2-5 second it turn off, no red light. when i remote to switch on then the red light is on and then press on again the lcd tv on after 2-5...
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
Oct 06, 2010 | Samsung LA40A450 40 in. LCD TV
My samsung lcd tv is lock on tv channels only
Check function buttons. One may be stuck. Disconnect the function switches from the switch board. If you can change inputs with the remote then replace switch board or switches. if not then replace the main board.
Mar 25, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Tv continually changes from video 1 to video 2 to video 3 etc... sometimes get black screen as well + menu items. Based on a suggestion, I removed the batteries from the remote but that does not help. This...
It sounds like a switch problem inside the TV if you have already tried removing the remote batts. Try replacing the switches behind the push buttons on the front of the TV. Also, if glass cleaner or some other foreign substance has run down the front of the screen and into the set, this can cause switches to short out and cause this problem. The part number for the switches is 23145227. Thanks for using fixya.
Jan 20, 2010 | Toshiba 32AF43 32" TV
Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
Apr 20, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LA40R81BDX 40 in. LCD TV Logo
630 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
