Question about Samsung BN59-00599A Remote Control
Samsung bn59-00599a remote
Is there a set up code for the motorola dch3416 set top box for this remote?
  • 2 more comments
  • Anonymous Jun 21, 2008
    I can't get my Samsung LCD tv remote control to work with my Comcast, Motorola DCT 3612 I set top box. Any suggestions on what I might do?
  • SEALE1 Jul 10, 2008
    NEED CODE FOR GENERAL INSTRUMENT CABLE BOX ON A SAMSUNG BN59-00599A
  • mrs_met Sep 06, 2008
    Just got ATT UVerse at my home. I have two Samsung LCD TV's (different models) and the ATT remotes do not work for me. Both are Motorola boxes. My non-Samsung TV works just fine so it is something specific to the Samsung TV's. In fact, I had the ATT guy here for 6 hours..switching boxes and wiring until we swapped out tv's and discoved it's the Samsung TV's. Any suggestions??
  • Anonymous Mar 22, 2014
    need code for set top box
Thanks for the suggestion. 038 worked for me as well - mjmangal
Posted on Jul 12, 2008
    Problem Solver:
Whoa thanks, ive been trying this for a long time i have the bn59-00599a remote trying to use it with my new samsung dct2529 cable box but it wouldnt work, i tried 038 and bam it works! thx alot
Posted on Jun 12, 2009
  • christianrua Jan 13, 2011
    my friend you are really good on this i was trying to fix this until i followed your advice and bam it was like a miracle thank you i really apreciate it god bless you
I have a samsung blueray player how do i program the remote to it
Posted on Aug 11, 2011
Cable - set - 038 Power Worked for me, hopefully will work for you as well.
Posted on Jun 22, 2008
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
Set motorola dch6200 remote control
You're probably better off programming the cable box remote to control your TV. Samsung codes are standardized, Motorola not so much.
Dec 30, 2013 | Televison & Video
I have a new Samsung smart tv and I'm trying to set up the universal remote setup feature with my Motorola DCH6200 Set-top box. It doesn't seem to recognize my set-top box model number
Find the manufacturers website for the universal remote and download the codes for samsung smart tv, probably will be able to find a general code in the online manual of the remote.
I received an error 4 code on my comcast supplied motorola dch3416 hd dvr, looking up this error on the web it was suggested that i reset the device, but did not specify how. can you help?
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
Mar 24, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
How to set a clock on a hd dual tuner dvbr dch3416
The clock should set automatically, synchronized with your cable provider's time. You can't change it, as far as I know. OR does it display the channel number and you want it to display the time? If so, go to your onscreen menu (home), choose setup, choose cable box setup, front LED display: current channel ----> current time.
Mar 14, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Two tvs off Motorola DCH3416
If you have different input options on your TVs, you could run the second TV with the Y, Pb,Pr component outputs along with the analog audio from the STB. However, remember the STB will only support ONE output video format. So both TV will have to be set to the same video format (720p, 1080i, 480p, etc)
Jun 20, 2009 | Arris DCT2608
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Samsung BN59-00599A Remote Control Logo
4,245 people viewed this question
Jerry Greenberg
Jerry Greenberg
