Question about Cameras
How to setup my edimax router to be able to see my Linksys ip WVC54GCA camera through the Internet ? i have setup the camera fully as per Linksys instructions.
  • 1 more comment
  • Mahmood Al-Qadiri Oct 05, 2010
    It's not working; I cant see the camera from outside my home Internet.
    I have assigned a static IP for the camera, and I can see it live if I go to 192.168.2.109:8080 through my home Internet, but I can't reach the camera from outside using myIPaddress:8080
    Also, I have activated DDNS to TZO address, and I still cant reach the camera using TZO provided address.
    Tried port forwarding ... did not work.
    If I want to enable DMZ, I get the table below:
    what values should I use for Public IP and Client PC IP ?
    Enable DMZ
    Public IP addressClient PC IP addressComputer name
    Dynamic IP
    Static IP
    This was great!
    The problem was with the firewall, and it's much better to enable the DMZ for the static IP of the camera rather than using port forward.
    The support from Ekse was so helpfull and I can watch my camera from outside location through the Internet.
  • 13,433 Answers
Hello
You need to Turn on Port forwarding from the router, that forwards the IP cameras connection port that shows you the picture on a internet browser or other tool.
You can find this port by normally connecting to the Ip camera Via Internet browser it will be on the address: HTTP://192.168.1.15:8080 for example. If that was the IP of the camera in your network, then you would need to either enable DMZ to ip 192.168.1.15 (camera ip) Or Enable port forwarding for camera IP and port 8080 as an example.
Also note that you can not efficiently test if your portforwarding was successfull from home, you need to try from outside. you can visit www.whatismyip.com to get your home IP address. now with this address you can browse from another computer outside of your home to HTTP://yourIP:cameraPort and the IP camera should be visible. It is recommended to turn on security - so that you need to enter a user name and password to the camera.
Posted on Oct 04, 2010
  • Ekse Oct 05, 2010
    Port forwarding tend to always be a bit of trouble to get to work properly. Since you can view it on the lan, you will be able to view it outside, we will just need to get the portforwarding to work properly, You could also try the DMZ setting for the camera's ip. Also check any security settings on the firewall, might be blocking http traffic from lan to wan. (from local area network to outside)
  • Ekse Oct 05, 2010
    Public ip is dynamic ip session 1, unless you know you have static ip? - go with dynamic.
    Client PC ip is 192.168.2.109
    Click Add
    Check Enable DMZ.
    Router should restart. - if it doesn't work, reboot router and try again. Also note if your camera IP changes this will no longer work, it might be better to set a static IP into the camera so its always for example 192.168.2.100
My edimax wireless access point is saying i have the wrong username and password and wont let me login
For most Edimax routers, the default IP address is 192.168.2.1, default username is admin and password is 1234.
By default the router is a DHCP server which will assign IP address starting from 192.168.2.100 to 192.168.2.199 to DHCP clients automatically.
Make sure your computer has TCP/IP Protocol setup as "Obtain IP address automatically".
Open the Internet Explorer.
Type in http://192.168.2.1 hit Enter.
The Login window will appear.
Type in the default username admin, password 1234.
Click on Login.
Then you can configure the router.
Sep 11, 2013 | Edimax Computers & Internet
I have a pldt plan 990, edimax br6428ns wireless router, se260 modem. can not connect to internet.
your internet provider provides a ip address.then configure your router to static and enter the ip that they gave to you and just set dhcp enable..then test if you have internet connection.after that setup your a password to your router.
Jul 13, 2011 | Computers & Internet
How i can to setup WVC54GCA without CD
Ok First... Go on Google (Type Exemple) Download Linksys WVC54GCA drivers for XP then follow the instruction..
Oct 06, 2010 | Linksys WVC54GCA Network Camera
WVC54GCA camera - setup is ok with cable install but once going to wireless, no go using Belkin N1 router
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
May 16, 2009 | Linksys WVC54GCA Network Camera
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Linksys wireless camera--viewable if ISP uses dynamic IPs?
Ok, everything by default hands out dynamic ip addresses. If the camera is plugged into the network it will automatically pick up an ip address and you would be able to see it in your router config page. Try attaching the camera to the wireless network and then log into your router and look for attached devices. Let me know if you get stuck and where you get stuck.
Regards
Dec 16, 2008 | Computers & Internet
My edimax prob.
Hi...
Use the setup wizard under Internet Explorer - (go to: Tools, Internet Options, Connections, Setup) Choose the right connection after the setup... close the IE browser and reload it... If it doesn't work... you have to set the IP and DNS to Auto.... keep me posted if your still have problems.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Cameras Logo
210 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
