Question about SanDisk Sansa c140 MP3 Player
Player frozen at the Sandisk logo
The player is stuck on the Sandisk screen.
I tried to update the firmware versionC100_ 1.0.005a FirmwareUtility.Exe
When connecting the device in recovery mode it detects the device and the update button is active.
On clicking the update button it says it is working, and then it fails.
Could you suggest any other setps to get the device working?
  • vrcmenon May 29, 2008
    I tried the mentioned steps but the player is not responding to any of them.
    Looks like the player, needs a replacment.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Sa2825 player has frozen and the reset does work.
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Dec 22, 2008 | Philips SA5125/37 MP3 Player
Frozen on "Refresh Database"
Thank you
Computerrep
Sep 25, 2008 | SanDisk Sansa Clip MP3 Player
FROZEN SCREEN
Attention: Resetting the device will delete all the songs...!
Thank you
Computerrep
Apr 13, 2008 | SanDisk Sansa m240 MP3 Player
Screen frozen
I would recommend you to go to the sandisk site to update the firmware on your device even if you have done so in the past or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
Thank you
Computerrep
Apr 03, 2008 | SanDisk Sansa E280 MP3 Player
My e250 screen is frozen on one song and will not play or change screens. the screen is frozen
Thank you
Computerrep
Apr 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problem with player
The reason its stuck is because your firmware appears to be corrupted...It wont take you long to updat the firmware..
Thank you
Computerrep
Mar 27, 2008 | SanDisk Sansa c240 MP3 Player
Stuck on refresh/black screen
Thank you
Computerrep
Mar 22, 2008 | SanDisk Sansa e270 MP3 Player
Stuck Screen
It seems as thought the player itself has actually frozen. I have the same player and it has never done this to me. If you havent allready try leaving it alone in a quiet place for a day or two until it runs out of battery. Then plug it in to your PC to charge and it should be okay. As this has happend to me with other players. If it isnt however, try to resolve the issue by somehow updating the firmware. Try googling "SanDisk Sansa e260 Firmware Upgrade" and see what you can find. If there is something which looks hopeful try it, but if it doesnt work, the perhaps the only option is to return or exchange the player at its place of purchase. P.S Check the USB modes.
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
Not working
If your player is frozen. Press and hold the menu button until it turns off and try to update the firmware of the player. And also it may be that the songs on your player is causing the problem try to format the player. How to update the firmware of the player please follow this steps. 1.Slide the hold switch for it to show the orange/red color. 2.Press and hold the record button and the menu button until it shows on the player screen Welcome to recovery mode. 3.Download and install the firmware update. 4.When the firmware update has been installed hooked the player to the computer and perform the update. Hope this helps. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
141 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
