I own a Zenith ZW5000T8 that is a little over a year old. This morning it starting making a noise and spewing water. I hope there is something I can do to resolve this.
    President:
  • 3,074 Answers
You can check to see if the unit is draining as it sounds as though it is clogged, usually if they make a noise like a fan blade hitting something then it froze(iced) up. If you think this happened unplug unit for about four hours and watch to see if water is continuously draining, if it is then it did freeze, if this is the case you will need to take the housing off and try cleaning the coils, this may help, if this is done and it still freezes then it is low on freon. Hope this helps tim
Posted on Oct 02, 2010
It's two years old, and is now spitting out lots of water.
Should have a drain on the unit. Check for ports that have debris in them on the outside of the unit. Clean the debris out and the unit should drain normally.
May 30, 2010 | Haier ESA306 Air Conditioner
Static and noise from right side speaker?
interfearence from something in house
May 01, 2010 | Yamaha Portable Keyboard
Zenith ZW5000T8 window unit is not cooling. It
You are the proud owner of a DUD! Your compressor is not able to come on, as it had frozen up (not in the icy sense of the word, but stuck) & the "buzzing" is the power trying to get the compressor to "juice up." This is a big pain in the rear, but grab the receipt & RETURN it!
Aug 28, 2009 | Heating & Cooling
Load noise when I turned on water for ice
I assume it was the water dispenser. It has a solenoid on the water inlet valve which can stick. Is the noise coming from the back where the inlet valve is.
Jun 30, 2009 | GE Profile Stainless Bottom-Freezer...
I have a 10 year old Zenith Color Tv the screen is blurry
It may need a focus adjustment or the CRT socket needs to be replaced. Look in from the inside for this parts.
Feb 09, 2008 | Zenith SY2751Y TV
Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
Jun 13, 2007 | Kenmore 40052
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
Heating & Cooling Logo
508 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
