Question about LG GH22LS50 DVD-RAM Burner
With Lightscribe, when I try to print an image, the program (I have tried SureThing and Droppix) says it is printing the image. After 20 seconds or so, it says printing is complete and ejects the disc, but there is nothing on it. I have tried different discs, custom and stock templates with the same result. I've had the drive for less than a month, but don't really want to spend the extra money to ship it back if it's simply something I'm doing wrong. Any advice would be appreciated.
5 Suggested Answers
Roonie Tunes
  • 136 Answers
SOURCE: LG DVD recorder no longer detects any discs in the drive
salleenstang --
POSSIBLE solution... (don't shoot the messenger on this one, lol!)
I'm sure you have tried, but have you cleaned your optics lately?
Using a Q-tip and a small amount of rubbing alcohol, and GENTLY rotate the swab across the lens, rotating it in the opposite direction you are wiping. This should "lift" any dust or grime from the lens. I would also clean the tray with a soft lint-free cloth (using an air-can just moves the dirt around, doesn't solve the problem) If that doesn't do the trick, respond to this thread and I will be happy to assist you further!
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Posted on Sep 19, 2009
Smeeagain42
  • 77 Answers
SOURCE: Disc drive will not open and discs will not eject.
You will need to manually eject the drive tray, please use the link provided to view a quick video on this subject. Video clip is better than writing a long instruction piece.
http://www.metacafe.com/watch/yt-2ScSLW2QxD4/how_to_manually_open_a_cd_or_dvd_drive/
As stated in this video, it is more likely with the age of the Drive
that it is not cost effective to repair it.
Posted on Apr 20, 2010
bronk50
  • 27725 Answers
SOURCE: I have DVD RAM (Super Multi Secure disc drive)
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty ?
good luck
Posted on Aug 30, 2010
SOURCE: OS is XP; using Roxio Creator 2009 trying to print
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall cd rom drivers then it automatic install drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. then check. Let me know if you need further assistance. Thanks for using FixYa
Posted on Aug 22, 2011
I have a Superwritemaster dvd/cd duplicator with lightscribe capability. But I can't get the lightscribe to work. Help!
>You need to install the drivers for Lightscribe; if you don't have them Google Lightscribe HP and you should find them on the HP website. Then you need a disk label burning program that runs Lightscribe. Droppix.com has a good one, I think HP also has a basic one.
Sep 26, 2013 | Samsung Super-WriteMaster SE-S164L DVD?RW...
Tip
LightScribe Disc Burning
How to burn a LightScribe Disc.
You need to download The Light scribe Template Labeler.
You can get it here. http://www.lightscribe.com/products/index.aspx?id=105
Pick your Platform. ie Windows,Mac,Linux
you can get Designs from here.
http://www.lightscribe.com/ideas/index.aspx?id=2564
Install the Template Labeler
You now need to insert a LightScribe Dsic Into the drive (Lable side down)
Now go to start and left click on the LightScribe Template Labeler Program.
On the first window you'll get an option to do not show again.(your choice)click ok
You are now in the labeler program.
pick a Template
You can download more Templates from a link centered near the top of the screen.
click next at the bottom of the screen.
The next screen you can edit your slected image.click Preview and Print when your done editing.
The next screen you can slect your color of choice and the drive as well as print options.
On the bottom right your estimated burn time will be displayed.
click print near bottom right.
Hope this helped.
on Jun 03, 2010 | HP DVD 740VI 16X16 Dual Layer LightScribe...
I'm trying to find out if ideasoft cd labeler premier edition supports printable cds
SureThing CD/DVD Labeler Deluxe DOES. $25 on they website. http://www.surething.com/ST/Category.asp?CatCode=ST4_HOME
and its called LIGHTscribe Technology where it prints on the CD. i could not find the premier edition.
hope this helped da404
Mar 01, 2010 | IdeaSoft Surething CD Labeler Full Version...
Lightscribe not making labels
hello, did you get firmware update for the lg unit? they give updates to give the drive more capabilities. if you bought the drive, and added it the lg updater is on the cd with all the other software,nero,ect. it is called lg odd auto firmware updater. this may help you,and i could not hurt the system. they give me 2 updates a year(love lightscribe) other possible things, did it stop working after a nero or other software change or update? if you need further assistance reply.
Mar 15, 2009 | Televison & Video
LightScribe installed properly, but not seen by other software.
Software problem with NERO and Surething LightScribe. Didn't see the "LightScribe' option in thier software.
Droppix Lightscribe software worked fine.
Dec 28, 2008 | HP LightScribe dvd640i (DVD640I)...
Why Can't I get my computer to print Lightscribe labels
Try going to www.lightscribe.com and using their program. It works really well for me
Dec 23, 2008 | HP LightScribe dvd640i (DVD640I)...
My dv9000 wont burn any cds. i am not sure why. i have tryed downloading some different software but it still wont do it. i know it can i have done it before. i also have lightscribe and i have used that...
1. Lightscribe needs its own drivers and a labeler like Surething CD Labeler
http://www.lightscribe.com/downloadSection/windows/index.aspx
2. If your HP came with sonic and you installed Nero or something else there is a good chance neither programs will work.
I had the same issues with my lightscribes (2) I thoughtlessly installed Nero without removing the Sonic Digital Media + in my HP the burner no longer worked, I reinstalled both programs after removal. I had to run the Nero Clean Tool first
http://www.nero.com/eng/support-nero7-tools-utilities.html
before the burner would work again.... only with the Sonic though Nero never did anything but mess up my burner, the lightscribe came back after installing the correct drivers, if your lightscribe is very light almost unseeable, then there is a contrast enhancer for the lightscribe
EXTENDED LABEL CONTRAST UTILITY
http://www.lightscribe.com/downloadsection/Windows/index.aspx?id=812
Sep 19, 2008 | HP Pavilion dv9000z Notebook
Burns blank
Try different software. Download nero trial at www.nero.com
Jun 05, 2008 | Lite On LightScribe (HP640VI) (HP640VI)...
Lightscribe doesn't seem to work
Do you have special Lightscribe coated disk inside?
Feb 04, 2018 | Computers & Internet
Lightscribe CD Burner
try and reinstall the sonic program if you have it. it sounds like the computer did not have the sonic software on it when you bought it, so it would have been removed when you restored your computer.
Nov 18, 2007 | HP DVD 740VI 16X16 Dual Layer LightScribe...
LG GH22LS50 DVD-RAM Burner Logo
130 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
