Question about Philips Audio Players & Recorders
I have Philips surround sound speaker system bearing Model No. A5.600. I am trying to install it in my PC but it could not be installed. I further tried to attach it with my dvd but its not working. Kindly help me in figuring out the problem.
DEAR , GIVE ME THE SERIE NUMBER OF THE REMOTE CONTROL
Posted on Nov 01, 2010
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
Nov 02, 2010 | Logitech X-530 Computer Speakers
Philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Sep 07, 2007 | Philips HTS3440/37 System
Philips lx3000d surround sound system. centre
cross check the audio device settings. check the audio level of each channels.
Also try exchanging the speakers whether the speaker itself is damaged.
Hope this helped.
Jan 05, 2010 | Philips LX3000D System
My Dell computer appears to have a sound card, yet I don't get any sound. The speakers work and are turned on.
Hi friend,
You have a sound card but you should install sound drives for sound. you can use..your motherboard cd for installation...
Dec 29, 2009 | Dell Dimension 1100 PC Desktop
Surround Sound Speaker
It sounds like you need to define the speakers to the PC. Find the icon that controls your Sound Card and dabble with it.
Dec 26, 2009 | Audio Players & Recorders
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
Not getting full 5.1 sound from PC to surround sound system
well if your motherboard supports your speekers it shoud run corectlly, but if not, you shoud get a special sound card with cd, which will allow you to use your speakers. if you already have that sound card and installed drivers you should go to your sound card control pannel and make changes there to use all your sound system speakers.
Dec 29, 2008 | Computers & Internet
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Computers & Internet
No sound...no... it is not the mute button
Did the TV produce sound along with the surround system in the past?
Verify the audio is connected through the TV and not directly to the surround system.
Usually there is an option in the TV setup to disable the internal speakers if the TV has variable audio output or audio pass-through. In Sony TV's this is usually one of the later menus and the option turns the TV speakers on or off, but it depends on the make/model of TV.
Apr 06, 2008 | Philips 32PF5320A 32 in. LCD Television
94 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
