Question about Dishwashers
Dishlex dx103 making a loud noise. is sounds like a grinding sound on every setting
  • 93 Answers
SOURCE: Whirlpool Dishwasher suddenly making a grinding noise...
Motors for tall tub whorlpools are over two hundred dollars. If its less than a year then its under warranty. You did not indicate model. If you can get back to me I'll look more in to seeing if it is feasable to repair or replace.
Posted on Jul 24, 2008
SOURCE: Dishlex global 300 dishwasher, eco
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Posted on Jan 09, 2009
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
subarufamily
  • 6 Answers
SOURCE: It has started sounding really, really loud with a long grinding sound and then like a swishy sound for a short break, then the grinding sound again.
Sounds like a piece of broken glass or hard fruit pit stuck in the garburator. Remove the botom rack and disassemble the eniter assembly located below the bottom rack. Keep track of the order of the parts until you reach the stainless steel garburator blade. If you are not mechanicaly inclined, take video of the dissasembley to help you put things back together. You will probably find a foreign object by the time you reach the blade. Continue disassembling the assembly below the garburator to ensure that the drainage ports are not obstructed. Consider re-assembling without the garburator blade to avoid recurring problems. Substitute Garburator blade with routine disassembley and cleaning every 3-6 months. Sadly thats the best way to overcome the failure prone Garburator mechanism. When its time to buy a new D/W, buy one with a filter instead of a garburator. I recommend Miele and recomend against all Whirlpool brands (Maytag, Jennair, KitchenAid, Kenmore, Whirlpool, WhiteWestinghouse, etc.)
When Garburators Jam, you risk overheating that can melt the overpriced circuit board or overheat the motor. Either problem means discarding the dishwasher becasue the repair cost would be too high. The Garburator is a disgusting idea anyway. Instad of allowing food particles to sit at the bttom, the sme particels are minced and sprayed over the dishes that you are trying to clean.
Posted on Jan 27, 2009
  • 423 Answers
SOURCE: our new LG dishwasher makes loud clunking noise
I believe this is a brand new dishwasher. Please listen carefully to determine of the sound you hear (clunk) is being made inside the dishwasher or is it being made near by. Most times, the problem is that the hot water pipe is baking the noise when the dishwasher closes the water inlet valve ... and the pipe goes "clunk"
I have not had an LG dishwasher make a clunking sound inside itself when the cycle changes. Also, because this dishwasher is so very quiet (well insulated) the pipe banging would be louder than something inside the Dishwasher.
If you have access to the hot water pipe, listen very near it when the cycle changes for the sound. Follow that pipe (hot water) pipe back and insulate it at the point it is banging. (or get a plumber to evaluate and resolve.)
Please get back to me with what you find, OK?
Good Luck!
Posted on Apr 07, 2009
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
Sep 19, 2009 | Electrolux Dishwashers
Loud grinding noise; new brakes and new tires
some of the brake material used will make that sound on toyota's and lexus.you need to try a differant type of brake pad.should help.
Jun 12, 2009 | 2004 Toyota Sienna
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
