Question about Xerox CopyCentre C128 Copier
Fault code 010-327 - Xerox CopyCentre C128 Copier
  • Xerox Contributor
  • 185 Answers
This is a fuser error, so we'd start by replacing that. The fuser PN is 126K16480.
This particular error code may be a false error, in which case either the Power Unit 105E11370 or the MCU Board 960K09910 might be bad.
Whit
Item, Inc.
Posted on Oct 21, 2010
  • 1382 Answers
SOURCE: code 010-327
These are the possible codes and the reason for occurence of this code in your copier
010-150, 155 -Too much or not enough paper in duplex tray
010-300 --Fuser thermistor, 010-302 --Low fuser temperature , 010-304-- Bad fuser temp, 010-308 --High fuser temperature or open thermistor, 010-310 --High fuser temperature , 010-312 --Fuser not up to temperature after energy save, 010-314 --Fuser problem , 010-320 --Fuser web finished , 010-330,327, 335, 340-- Exit switch, vertical sensor switch actuated when power is turned on
Thank you!!
Posted on May 18, 2010
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
goodgold
  • 389 Answers
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Posted on Sep 13, 2009
wrinaldo
  • 185 Answers
SOURCE: I have received an error code of 010-327 and I
Fuser thermal error. Check for paper wrapped around the rollers, but you will need to replace it.
PN 126K24980
Whit
Item, Inc.
Posted on Aug 13, 2010
SOURCE: ERROR CODE 010-327
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  3. Press the power switch to the ON position.
IF THAT FAILS TRY THIS NEXT:
Solution : Clear the Paper Jam Behind Cover A
  1. Open Paper Tray 5 (Bypass Tray).
  2. Lift up the Cover A release lever, and open Cover A.
  3. Remove any paper below the Fuser Unit by carefully pulling up and out.
  4. WARNING: Do not touch the Fuser Unit, as it may be hot.
  5. If the jammed paper is inside the Fuser Unit, lower the green A2 lever in the direction of the arrow to open the Fuser Unit Cover.
  6. Push down and rotate the green A1 lever in the direction of the arrow to feed the paper from the top of the Fuser Unit.
  7. NOTE: Do not pull paper downward during removal.
  8. Close Cover A until the cover latches.
  9. Close Paper Tray 5.
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
Posted on May 29, 2011
Refrigerator
all available online
  • Appliance Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair List of Appliance fault codes and Appliance error codes for all Appliance appliances. Free tech support.
  • Refrigerator Error, Fault or Function Codes - GE Appliances www.geappliances.ca/.../refrigerator-error-fault-or-function-codes Fault code Definition; FF: Check frozen food for thawing because the temperature is rising too high. PF: The power to the refrigerator has been interrupted.
  • Fault Codes - RepairClinic.com www.repairclinic.com/RepairHelp/FaultCodeLinks Fault Codes. Our Repair Help is model number driven. Once you provide the model number for your product type we can provide a list of the most common symptoms for ...
  • Related searches for refrigerator fault codes
  • http://www.bing.com/search?q=refrigerator+fault+codes&qs=n&form=QBRE&pq=refrigerator+fault+c&sc=0-20&sp=-1&sk=&cvid=3FD49316383B43288E0AB1ED81167DF7
    Jul 07, 2016 | Refrigerators
    What does an F-1 code mean on the display? washer will not start.
    power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Hi!Can you help me resolving error code 092-315 for xerox7225?
    Can you verify the error code? 092-315 does not appear in the error code site. See link below
    How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
    To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
    Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
    Viewing Fault and Alert Messages on the Control Panel
    When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
    To view a complete list of active fault and alert messages:
    1. Press the [Machine Status] button on the Control Panel.
    2. Select the [Active Messages] tab.
    3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
    4. To view details, select a fault or alert.
    Viewing the Fault History on the Control Panel
    When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
    To view the fault history:
    3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
    The following table represents the system area as represented by the first 3-digits of the fault code:
    Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
    http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
    Mar 07, 2016 | Xerox Office Equipment & Supplies
    MY YBR ENGINE MANAGEMENT LIGHT FLASHES 3 SHORT FOLLOWED BY 3 FAST
    That indicates fault code 33 which is a faulty ignition coil
    Fault code 12 - Crankshaft position sensor
    Fault code 13 - Intake air pressure sensor
    Fault code 14 - Intake air pressure sensor
    Fault code 15 - Throttle position sensor
    Fault code 16 - TPS
    Fault code 19 - No signal from ignition to ecu
    Fault code 22 - Intake air temp sensor
    Fault code 28 - Engine temp sensor
    Fault code 30 - Tip over sensor
    Fault code 33 - Igniton coil
    Fault code 39 - Fuel injector
    Fault code 41 - Tip over sensor
    Fault code 44 - Read write error ECU
    Fault code 46 - Power supply error to FI system
    Fault code 50 - Ecu malfunction
    Jan 08, 2015 | 2009 Yamaha yBR125
    How do I fix code 13 engine speed sensor Above 1000 rpm
    Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
    Here are some common Lexus vehicles 1990-1995 codes:
    Code 12 and Code 13 Rpm signal circuit fault
    Code 14 Igniter signal circuit fault
    Code 16 ECT control signal fault
    Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
    Code 22 Coolant temperature circuit fault
    Code 24 Intake temperature sensor circuit fault
    Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
    Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
    Code 31 Low airflow meter voltage (for ES300 and GS300 models)
    Code 32 High airflow meter voltage (for ES300 model)
    Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
    Code 41 and Code 47 Throttle position sensor circuit fault
    Code 42 Vehicle speed sensor circuit fault
    Code 43 Starter signal
    Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
    Code 52 Code 52 and Code 55 Knock sensor circuit fault
    Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
    Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
    Nov 18, 2014 | 1990 Lexus LS 400
    What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
    Hi Judy,
    According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
    The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
    I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
    FLASH CODES
    Code #1
    • Flash Code: One, pause, one
    • Cause: Possible Stall Timeout
    • Possible Solution: Turn joystick off, then on.
    Code #2
    • Flash Code: Two, pause, two
    • Cause: Battery Fault
    • Possible Solution: Charge batteries, check battery connections and fuses.
    Code #3
    • Flash Code:Three, pause, three
    • Cause: Left Motor Fault
    • Possible Solution: Make sure the left motor is plugged in.
    Code #4
    • Flash Code: Four, pause, four
    • Cause: Right Motor Fault
    • Possible Solution: Make sure the right motor is plugged in.
    Code #5
    • Flash Code: Five, pause, five
    • Cause: Left Park Brake Fault
    • Possible Solution: Make sure the left brake is not in freewheel mode.
    Code #6
    • Flash Code: Six, pause, six
    • Cause: Right Park Brake Fault
    • Possible Solution: Make sure the right brake is not in freewheel mode.
    Code #7
    • Flash Code: Seven, pause, seven
    • Cause: Joystick Fault
    • Possible Solution: Check the joystick connection.
    Code #8
    • Flash Code: Eight, pause, eight
    • Cause: Power Module Fault
    • Possible Solution: Check connections to the power module and batteries.
    Code #9
    • Flash Code: Nine, pause, nine 9
    • Cause: Controller Communication Fault
    • Possible Solution: Check bus connections from the joystick to the power module.
    Code #10
    • Flash Code: Ten, pause, ten
    • Cause: Controller Fault
    • Possible Solution: Contact Technical Service for assistance.
    Code #11
    • Flash Code: Eleven, pause, eleven
    • Cause: Incompatible Device Fault
    Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
    Truck will be running fine, then all of a sudden it will completely shut off. After we wait a few minutes and pump the clutch and make sure it is all the way to the floor it will start, sometimes. S
    You need the engine computer scanned for fault codes, i thank you have an ignition control problem like a module or distributor pickup coil issue. These parts whenthey fail should leave fault cdes so get them read.
    Next, the check engine light will pause shortly followed by the second digit of the trouble code. For example if the check engine light blinks once and pauses followed by six blinks the trouble code number would be 16. If no code is present the check engine light will stay one constantly. To restart code gathering turn the ignition key to the "off" position, wait three minutes and turn the ignition key back "on" again without starting the engine. Remove the jumper wire once code gathering is complete. To clear code after the repairs have been made remove the negative battery cable for one minute and reconnect.
    Toyota Diagnostic Connector
    Toyota Code Definition Table
    Code 11 Momentary interruption in power supply to ECU (electronic control unit or computer) up to 1991
    Code 12 Engine revolution signal missing Code 13 Rpm signal to ecu missing above 1000 rpm
    Code 14 Igniter signal to ecu missing
    Code 16 A/T control signal missing from ecu
    Code 21 Main oxygen sensor signal fault
    Code 22 Water temperature sensor circuit fault
    Code 23 and 24 Intake air temperature signal fault
    Code 25 Air/fuel ratio LEAN
    Code 26 Air/fuel ratio RICH
    Code 27 Sub-oxygen sensor signal or heater circuit fault
    Code 28 No. 2 oxygen sensor/heater signal fault
    Code 31 and 32 Air flow meter circuit or Vacuum sensor signal fault Code 34 and 36 Turbo-charging pressure signal fault
    Code 35 Altitude compensation sensor signal fault
    Code 41 Throttle position circuit fault
    Code 43 No starter signal to the ecu
    Code 51 AC signal on; DL contact off (in transmission shifter with diagnostic connector jumped)
    Code 52, 53 and 55 Knock sensor fault Code 71 EGR system malfunction
    Code 72 Fuel cut solenoid signal fault
    Code 78 Fuel pump control signal fault
    Code 81, 83, 84 and 85 TCM communication fault
    Jun 28, 2012 | Cars & Trucks
    The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
    I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
    Fault Code: 12
    Symptom: No normal signals are received from the crankshaft position sensor.
    Fault Code: 13
    Symptom: Intake air pressure sensor-open or short circuit detected.
    Fault Code: 14
    Diagnostic Code: 03
    Symptom: Faulty intake air pressure sensor pipe system
    Fault Code: 15
    Diagnostic Code: 01
    Symptom: Throttle position sensor-open or short circuit detected.
    Fault Code: 16
    Diagnostic Code: 01
    Symptom: A stuck throttle position sensor is detected.
    Fault Code: 19
    Diagnostic Code: 20
    Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
    Fault Code: 21
    Diagnostic Code: 06
    Symptom: Coolant temperature sensor-open or short circuit detected.
    Probable cause of malfunction: Open or short circuit in wiring harness.
    Defective coolant temperature sensor.
    Malfunction in ECU.
    Improperly installed sensor.
    Fault Code: 22
    Diagnostic Code: 05
    Symptom: Intake air temperature sensor-open or short circuit detected.
    Defective intake temperature sensor.
    Malfunction in ECU.
    Fault Code: 30
    Diagnostic Code: 08
    Symptom: The motorcycle has overturned. Probable cause of malfunction:
    Overturned.
    Malfunction in ECU.
    Fault Code: 33
    Diagnostic Code: 30
    Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
    Probable cause of malfunction: Open circuit in wiring harness.
    Malfunction in ignition coil.
    Malfunction in ECU.
    Malfunction in a component of ignition cut-off circuit system.
    Fault Code: 34
    Diagnostic Code: 31
    Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
    Malfunction in ECU.
    Fault Code: 41
    Diagnostic Code: 08
    Symptom: Lean angle cut-off switch-open or short circuit detected.
    Defective lean angle cut-off switch.
    Malfunction in ECU.
    Fault Code: 42
    Diagnostic Code: 07, 21
    Symptom: No normal signals are received from the speed sensor; or, an open or
    short circuit is detected in the neutral switch.
    Defective speed sensor.
    Malfunction in vehicle speed sensor detected unit.
    Defective neutral switch.
    Malfunction in the engine side of the neutral switch.
    Malfunction in ECU.
    Fault Code: 43
    Diagnostic Code: 09
    Symptom: Supply power to the injector and fuel pump is not normal
    Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
    Malfunction in ECU.
    Fault Code: 44
    Diagnostic Code: 60
    Symptom: An error is detected while reading or writing on EEPROM.
    Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
    Fault Code: 46
    Diagnostic Code: --
    Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
    Malfunction in "CHARGING SYSTEM".
    Fault code: 50
    Diagnostic Code: --
    Symptom: Faulty ECU memory. When this malfunction is detected, the code
    number might not appear on the meter.
    Probable cause of malfunction: Malfunction in ECU. (The program and data are not
    properly written on or read from the internal memory.)
    Fault code: Er-1
    Diagnostic Code: --
    Symptom: No signals are received from the ECU.
    Probable cause of malfunction: Open or short circuit in wiring sub lead.
    Malfunction in meter.
    Malfunction in ECU.
    Fault code: Er-2
    Diagnostic Code: --
    Symptom: No signals are received from the ECU within the specified duration.
    Probable cause of malfunction: Improper connection in wiring sub lead.
    Malfunction in ECU.
    Fault code: Er-3
    Diagnostic Code: --
    Symptom: Data from the ECU cannot be received correctly.
    Malfunction in ECU.
    Fault code: Er-4
    Diagnostic Code: --
    Symptom: Non-registered data has been received from the meter.
    Malfunction in ECU.
    Feb 23, 2010 | 2005 Yamaha FZ6
    Trouble Codes
    1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
    Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
    Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
    2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
    Fault location = Malfunction Indicator Lamp (MIL) - request signal active
    Probable cause = Trouble code(s) stored in other system(s)
    3. VW VAG type 5 digit fault code 01039:
    Fault location = Coolant Temperature Sensor (G2)
    Probable cause = Open or Short to Plus, Short to Ground - Intermittent
    4. VW VAG type 5 digit fault code 01304:
    Fault location = Radio
    Probable cause = No Communication
    5. EOBD type P0761 fault code:
    Fault location = Shift Solenoid C
    Probable cause = Performance or Stuck OFF
    Feb 03, 2010 | 2002 Audi A4
    Xerox CopyCentre C128 Copier Logo
    1,280 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
