Question about Rode NT1A Professional Microphone
It sounds like wind is blowing into it - Rode NT1A Professional Microphone
Why does my onkyo receiver sound like wind is blowing through the speakers
If this is present in all sound modes then it sounds like a faulty part, possibly a leaky capacitor or other device.
Feb 09, 2015 | Onkyo Audio Players & Recorders
Why doi have a winding sound in my SUV in almost every gear
Sounds like a blown head gasket - This will damage the transmission of the SUV if the hoses where blown off the radiator . Had it happen to a car. When the gasket is blown pressure builds in the vehicles cooling system until it builds to a point where it blows the hoses off the pipes or blows up your radiator. The transmission may also have a cooling system that has been damaged from the pressure build up. Get a radiator dude to put a cap on your radiator with a pressure gauge and then run the engine and see if the pressure climbs on the cooling system.
Aug 04, 2014 | 2001 Ford Escape
Toyota air conditioning
sound like faulty AC compressor pulley clutch has a short in the windings or wiring to compressor has short.
Aug 02, 2013 | Cars & Trucks
Is their a resistor in series of the blower motor that could be the problem of not blowing air
Resistors are for reducing voltage to anything in an electrical circuit, and what you describe sounds like a motor that is giving out. When hot, it cuts out or quits working, but cools down and begins again. This is most likely due to the windings having shorted out somewhere in the windings. Some motors have a breaker switch located "inside" the motor casing.
Sep 07, 2012 | 2007 Ford Edge SEL Plus
I recorded videos at a concert with the new nikon coolpix L810 and the sound on the video is horrible.What is causing the noise in my video? sounds like wind is blowing or a crackling noise
The problem is the microphone on the camera. The mic on the camera is for recording sound in more normal environments. The sound level on a typical concert is much higher than normal, and the mic on the camera just doesn't have what it takes to record sound at those levels.
One possible solution is to record the sound with a dedicated audio recording device, and combine the video and audio in your video editing software.
Jul 02, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
Load chirping noise in dash on drivers side
I have the same issue with my 2005 corolla and finally decided it was the wind blowing through the windshield wipers to the vent. nothing i could do to fix the issue either.
Mar 12, 2012 | 2003 Toyota Corolla
My 2704 is blowing fuses, there is no fault on the lead
You may have a motor winding lead that has touched the case of the motor, shorting out the windings, drawing too much amperage, thus blowing fuses. You may have to disassemble your motor and check the stator windings for a short as well as the armature windings. Also the motor could be hanging up due to bearing trouble and causing the motor to draw too much amperage. Probably the cheapest thing to do would be to replace the motor.
Jun 08, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
Start capacitor keeps blowing. saw starts up
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
May 13, 2010 | Diamond Products Mk - 101 10" Tile Saw
Rode NT1A Professional Microphone Logo
57 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
