Question about Canon PIXMA iP1800 InkJet Photo Printer
Output of color red image is color yellow - Canon PIXMA iP1800 InkJet Photo Printer
  • Canon Master
  • 32,281 Answers
The Magenta color cartridge is either empty or the print head is blocked.
Posted on Oct 02, 2010
How do i conect a dvd player to a Model UE32C5100QW
This will depend on the output type(s) of your DVD player.
If the outputs on the rear of the DVD player are Yellow (vodeo), Red and White (left and right audio) then you will use standard Composite RCA cables running to the A/V inputs of matching colors on the rear of your TV.
If the DVD outputs are Red, Blue, Green (video) and Red and White (audio) then you will use Component RCA cables leading to the appropriate inputs of matching color on the rear of your television.
Both of these methods will produce a standard definition image and you made need to adjust your television to get the image to display properly. You will also need to use your remote to switch to the appropriate input you used.
In some cases newer DVD players may have an HDMI output and you can use that to connect to one of the HDMI inputs on your TV. However, this will still produce a standard definition image although the DVD player or your TV may "upscale" the image to try and produce a sharper and cleaner image.
RCA cables, both composite and component, are available at retail stores such as Walmart, Best Buy or other electronics retailers. You can also find them online via Amazon, Newegg or other electronics retailers. Most shouldn't cost much and probably considerably less than a quality HDMI cable.
Feb 28, 2015 | Televison & Video
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
I just bought a Philips Smart WiFi Bluray Player BDP2105F7 and I cannot connect it to my old tv which is a sony triniton, I have image but no sound. There are two outputs on the dvd player but I have...
Your white red yellow cord is a Stereo sound + video cord. The red and the white ends are for sound the yellow end is for video - if your TV is not stereo it may not have the red and white it may only have one in which case you need to find an adapter from stereo to Mono to fit your red/white cable ends into a single connection on the TV. Or you can buy a home theater sound system and it will give the TV its signal and it will keep the stereo signal and broadcast it through the sound system.
Sep 15, 2017 | Philips Televison & Video
Can't figure out which color cables go where on tv to dvd
follow the color code, red white and yellow from dvd output to red white and yellow tv input, match the color of cable end to color inside the jacks of the units
Mar 10, 2013 | Philips Televison & Video
Red filter on images
replace the color image units with OEM cartridges
Apr 29, 2012 | Konica Minolta magicolor 2300DL Laser...
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Need instructions to hook up dvd
Check Carefully on the Back on the DVD You will see different color RCA plug yellow, Red and white Input and Output The yellow output from your DVD go on the input TV ...Then the red output go in our red TV input Same for the white RCA plug sample to do ...
Sep 21, 2010 | Vizio VX42L 42 in. LCD TV
Dont realy have a problem just ned to know how to set up to my tv
There is an output for this device colored red, white and yellow. So the red and white is for the audio and the yellow is for video. Use an RCA cable with the same color. plug it at the back of your dvd matching the colors of the output jack and plug the end of the cables to the input part of your tv. So the red and white should be plug in to the "AUDIO IN" and the yellow should be plug in to the "VIDEO IN" on your tv, Set the tv to video and press play on the dvd.
Sep 09, 2010 | Haier Portable DVD Player PDVD7
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Dec 29, 2009 | LG Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Canon PIXMA  iP1800 InkJet Photo Printer Logo
51 people viewed this question
old marine
old marine
