Kenmore Elite Heavy Duty King Size Capacity Top Load Washer Won't Spin/Agitata
Yesterday when washing clothes there was a burning smell, the washer stopped and a fuse was thrown. When I checked the washer it would not spin, empty or agitate. When the spin cylce is turned on there is a humming sound but no movement. The model # is11020932992. Is this something I can fix?
  • 3 more comments
  • annemarye May 26, 2008
    There are no other noises and the agitator can be moved by hand without problems.
    Thanks for your help.
  • Anonymous May 27, 2008
    The exact same thing just happened to me with the same waher. How weird.
    I was told by a handy man that the motor was shot. He pulled off the pump and was able to get the washer running by manually spinning the drive on the motor but with the pump back on it didn't work again.
  • Buck Whyte
    Buck Whyte May 11, 2010
    Is there any other noises? Can you move the agitator by hand?  You are probably going to have to have a tech come out
  • Anonymous Mar 23, 2014
    It's a front loads heavy duty king size
  • 46 Answers
I am sorry to say that you WILL need a tech to come out and service this unit.  From what you are telling me it is either a dead short in the motor, OR one of the conntections got wet and cause a short.  BUT I would put my money on the motor, since this is a direct drive unit.  Sorry
Posted on May 26, 2008
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What capacity is a Kenmore Elite, king size, heavy duty washer model 110.22952100 ?
3.8 cu ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 19, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore elite oasis keeps stopping on spin and flashing ul it is a top loader king size capacity
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Washing Machines Logo
476 people viewed this question
Top Washing Machines Experts
