Question about LG Washing Machines
I need to replace the front door seal on a LG intellowasher WD8015-C
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
  • 4 Answers
SOURCE: The door seal is torn.
Pay the repair guy, even if it didn't include the part (seal) its cheap at $200. I replaced my door seal, I think the part cost me $36. In order to do the job correctly you need to remove the top, take off the front, remove the counter weight (to get room to work and not bust your knuckles). If you have an older machine the replacement seal is not a direct match. My seal won't allow the door to close completely and i have to lean on it to allow it to lock on start. I have had the seal in for about 4 months and am noticing the door closes better and I only have to lean on it a couple of times.
I replaced my seal because of the mildew problem caused by poor drain hole design. How does your seal get torn?
Posted on May 15, 2008
  • 489 Answers
SOURCE: LG WD-1021-WF Front Loader Washing Mashing
Replacing the door seal is not an easy task.  You will need to get 2 special tools from LG to make it as easy as possible.  The spring loaded clamps are very hard to put on because the springs are so strong.  Once you get the special tools, remove the front clamp off the door seal.  Pull the seal off the lip to gain access to inner seal clamp.  Remove the inner clamp and pull off the rubber door seal.  Just reverse the procedure when reinstalling the new seal.
Posted on Jun 26, 2008
  • 49 Answers
SOURCE: How to replace the door bellows seal ?
you must remove the large front panel. if you can manage that the rest will become clear to you. dont forget to unscrew the door lock before befor removing the front panel. you will find three screws at the bottom of the front panel under the kick panel, remove them and the front panel will come off.
Posted on Aug 18, 2008
wayneard
  • 1901 Answers
SOURCE: I need a manual for my (excellent) LG WD8013F Intellowasher front
Here is a link to LG's Support Site:
WD8013F Manual Page
This file is in .djvu format. You will need to install the Djvu Viewer if you do not have it installed. There is a link on the page to do so. Install the viewer and then go back and click on the manual link to open it.
Posted on Dec 03, 2008
WD-8050FH, LG Intellowasher washing machine, front door gasket is twisted. What is the likely cause?
Broken spyder. The three arm hub that attaches to the inner tub. It is replaceable. Open door and wiggle inner tub. If it moves inside of outer tub, that's a sure sign.
Oct 01, 2017 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
LG Intellowasher 7kg wd-8015c leak
Most of the time it is the door seal, open the door and check all the way round. check the sump hose and pump, sometimes it can leak from the soap draw hose to the outer tub, but not in your case I think. In most cases this can be fixed easy and is the door seal. to find out if it is coming from the front or the back, just place some news paper on the floor under the machine and take a look to see if it is the front or the back. a door seal is about 15/25 pounds retail
Oct 24, 2012 | Washing Machines
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Leaking at front door steel ring snapped where do u get parts from
The new part is simple to fit below is a link to a local retailer who will be able to supply the part.
Link:
Mar 11, 2012 | LG Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
HOW DO i REPLACE THE LARGER RUBBER SEAL ON A lg INTELLOWASHER 7KG WD 8013f . The seal is mildewed
I have this problem and have been told the following.
You have to take 2 Cir clips off. one on the front which is achievable by opening up the spring that holds it in place. The second one is behind the front panel.
You need to take the top off first. Undo two screws on the back top. Then you can take the top off. Then take any detergent tray our and also the front control panel. Then you gain access to some screws which hold the front panel onto the chassis.
After you take the front panel off you can apparently access the rear cir clip and spring.
once this is removed you can remove the front seal for replacement.
Jun 15, 2009 | LG Washing Machines
Washing Machines Logo
283 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
