Question about Altec Lansing MX5021 Computer Speakers
The cables are connected and working fine... the LED on the remote is on and when i decrease or increase the volume the led works on the command... but there is no sound from the speakers. How do i get to know if the remote is not working or the sub woofer? Where can i get the speakers repaired from authorized service centre in mumbai?
  • 62 Answers
Hello sir just chek you remote whether cells are weak or not..........there is very rare possiblity of spepeak damage
Posted on Oct 02, 2010
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
I have a panasonic th42px60u my problem is that none of the controls work xcept the on and off volume is on but unable to increase or decrease the volume.
Hi Daniel,
May I know if the remote control is working fine except from the front panel's volume and channel button key?
Jdvillanueva
Nov 23, 2011 | Panasonic Televison & Video
Remote was working fine.all of a sudden it stopped working.I put new batteries but still don't work.What could be the problem?
First of all check if the remote is working. How do we check the remote? Use your phone camera. While watching the LED in the remote through your mobile camera, press any remote button. You should see the LED flashing. You can't see the LED flashing by naked eye but with the help of camera you can. If the remote LED transmit the signal (if it flashes) then the remote is working fine. In this case your TV has the problem. If you can't see the LED flash, then your remote is the problem.
Open up your remote and check if there is dry or broken connection, or short connection.
Aug 31, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How do you reset the Projector after installing a new lamp?
There are two common methods to reset the lamp counter on these projectors: Method 1: - Press the decrease volume button on the remote and then the increase volume button within 3 seconds. - The LED light on the projector will turn green. - Turn on the projector. Method 2: - Turn on the Projector. - Open the standard menu using the remote. - Then select "Setup" or "Service" depending on your projector model. - Then select "Reset Lamp Timer" hope this solution has been helpful?
Jul 19, 2010 | Sharp Projector lamp Projector Lamp
Harmony remote control - volume won't stop increasing when the button is pushed
First I would check if the remote is momentarily sending out the volume command or is it sending it out continuously. You can use this trick with any IR remote. Using a digital camera with display, point the remote at the camera and press the volume button on the remote. If the IR led is working then you should see it glow on the cameras screen. When you release the volume up button, the IR led should stop glowing. If it does not stop then you may have a sticky key or a problem with the program. If it shuts off then the Harmony is functioning ok and there is a problem with your receiver. Another way to test this is to press the volume up button and then immediately cover the remote with a blanket or take it to another room or remove the batteries. Let me know if the remote is continuously sending out the Volume command or is it momentary.
Hope this helps.
May 02, 2010 | Logitech Harmony One Advanced Universal...
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
Mouse pointer remain always constant and has volume problem.
mouse malfunctioning.
is it a optical mouse you have to replace sensing LED.if it is not lit .use normal red or white LED.
hard to do this please change the mouse and try.
nuwan
Jan 10, 2009 | Intel BOXDG33FBC Single Pack Uatx G33 Exp...
Viewsonic remote RC00070P
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Jun 10, 2008 | Televison & Video
Altec Lansing MX5021 Computer Speakers Logo
136 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
