Question about NEC Televison & Video
Nec px42vp plasma, has two vertical black lines about 1" wide, running top to bottom of screen. All other functions perfect. What is the likely cause, what board is it on, is it an easy fix?
wyoed1
  • 211 Answers
SOURCE: green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: blue vertical lines
Yes...your light engine/optical block is shot... 1500 dollars.
Posted on Jan 25, 2008
  • 395 Answers
SOURCE: lg 37 inch lcd has
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
Posted on Feb 15, 2008
  • 116 Answers
SOURCE: vertical lines WD-62525
Most likely the formatter board. Are these lines across the whole screen?
Posted on Mar 05, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Magnavox 50mf231d/37 plasma has vertical
See if the vertical line appears when you press the "Menu" button on the Magnavox. Also, see if the line appears when you watch a dvd on the maganavox. If it does not appear, then the problem is the cable wire or cable/satellite box. You can reset the cable box and the TV by powering them both off, and leaving them unplugged for 20-30 seconds, and then replugging. See if that works.
Posted on Apr 16, 2008
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Black line on Panasonic Plasma
go here and follow, it will work!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Sep 20, 2007 | RCA L26WD26D 26 in. LCD TV
Televison & Video Logo
135 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
