HAVE A PACKARD BELL LAPTOP EASYNOTE F 5275 IT HAS CMOS PROBLEM IT CANNOT BOOT WITHOUT SETTING CLOCK AND DATE AND THERE IS NO ANYWHERE IN MOTHERBOARD I CAN SEE THE CMOS PLACE KIND ASSIST
  • josekaliti Oct 02, 2010
    i keep on setting date n time every now n then is there a permanent solution coz in kenya it seem no technical support plz. in the motherbord no place for cmos.
  • 4,924 Answers
Try to boot and when it asks to set the time and date ..press F1 to go to the BIOS settings and in there save like it is with F10..and enter ..will start anyway and you will set the time in windows..
or ...go to bios directly by pressing F10 if it is a HP computer or ..F2 for any other laptop ..and in there on the time settings just set the time and the date from the arrows and enter ..
if you have other problems and you opened it ...you will have to remove the Bios battery to default it to the factory settings ..this will eliminate any passwords that might had kept you out of bios...if you do not see the battery ..remove the wireless card and see if it is under it ..
Posted on Oct 02, 2010
  • Catalin Turcu
    Catalin Turcu Oct 02, 2010
    im not sure if my second comment got to you ..so I repeat ..even if you remove the battery ..this will just get you back to setting the time ..so if you do not have any problems with passwords...I see no reason to do it...just press F1 when it asks for the time for to boot..and save the time that it is there ....with F10 ..reboot and set the real time from windows..
  • Catalin Turcu
    if after you shut it down or ..probably when the laptop is closed and the battery drained out ...you have to reset the date and time ...and inside the files do not keep their program associations ..this means that the Bios battery is dead and there for it can not keep the settings in bios or in windows that depends on the flash memory of the bios..so you need to change the Bios battery or see what's wrong with the contacts if after changing it makes the same ..probably it has a loose contact on bios battery ...but I doubt it cause in this case it will not boot at all..
    so ..change the bios battery if it do not keep the settings after you shut it down completely ..
Packard bell easynote M5284 - black screen after installing new RAM
Sounds like the memory is incompatible with the laptop. Remove the memory and install orginal memory and boot again to see if every works correctly.. If so then either a memory module is bad or motherboard wont support the new memory (size or type)
Mar 14, 2013 | Packard Bell EASYNOTE M5284 COMPATIBLE...
I have a Packard Bell EasyNote TH36. The laptop won't boot up. It's stuck on the purple Packard Bell page, I cant access BIOS and I can't click F12 - When I do it just freezes on the boot
make sure that your RAM and Cmos battery have dust free secure seatings
some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
Jun 28, 2012 | Packard Bell Computers & Internet
How to system restore my packard bell easynote tj71
When the laptop boots up, go to Start - All Programs - Accessories - System Tools - System Restore - click on "restore My Computer to ab earlier time" and click on a date you wish to restore from (before your problem occured).
Mar 24, 2012 | Packard Bell Computers & Internet
Where is the cmos battery on easynote r0901?
Hi moose2990, this is a [Picture Diagram].
CMOS Battery on the "Motherboard!"
replace-packard-bell-486-battery-200x200.jpg "This is a "Picture of a CMOS Battery on a {Packard Bell} Motherboard."
"This is a picture of a [CMOS Battery], on 'most' Motherboards!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 09, 2011 | Packard Bell (181368) Motherboard
When I am trying to boot up my Laptop ''Packard Bell Easynote'' I get the following message: Resource Conflict - Allocation error static node #0B Warning: Cannot Unlock Primary HDD Press Enter to resume....
you can fix that problem with your own. press f2 and then correct the time and date, then press f10. I f you got same problem again change the cmos battery then do it again.
Feb 15, 2010 | Computers & Internet
Easynote will not go past packard bell screen
You may need BIOS update. Check your CMOS time at bios page.
If time is wrong, set it up and try again. If this is solved the problem, change the CMOS battery.
JMC
Aug 15, 2009 | Computers & Internet
Packard Bell easynote
problem with processor or motherboard find it out!
Nov 06, 2007 | NEC Laptop Motherboard (1580262530)
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
