Question about LG Flatron L1515S 15" LCD Monitor
Pl. solve my problem "PROCESSING AUTO IMAGE ADJUSTMENT" message display continusly
    New Friend:
I've tried all ideas by removing this ,,processing auto image adjustment'", but all of them was not working. So, i found truly and simple solution: The problem is made of constant autoself incorrect working button ,,Auto/set". This button is near ,Turn off/on monitor". Eventually you need to turn off this button, but there is no solution to do it, but i found one - i used hair clipper to press this button PERMANENTLY. And it WORKED, and also no screen buttons are working
Posted on Apr 03, 2013
I have the identical problem
Posted on Oct 18, 2010
I am getting Processing auto image adjustment popup continuously. Help me how to stop it.
You'll probably have to turn an auto-adjust option off within the monitor settings.
Feb 18, 2018 | Computers & Internet
Screen often displays a window with this text: "processing auto image adjustment"
that is a windows screen and not the monitor. check to see if you are out of range on your resolution and geometry.
Apr 01, 2015 | Computers & Internet
My HPL1940T montor shows a jumpy image en the warning "Auto adjustment in Progress": keeps ******* up. How can I solve this problem. I'm sorry for possible mistyping in this messag, but de...
Check the buttons on the sceen. there is a button which says AUTO. Might be that button is pressed. Try to check the reason for that and release that button, it will be fine.
Sep 17, 2011 | HP L1940T 19" LCD Monitor
I changed the screen resolution from 1024 768. while booting the monitor goes to power saver mode and displays "Out of Range 53.7KHZ to 60Hz. My OS is Win XP sp 3,
If the monitor is able to display the video after the computer boots, it may be something that you will have to live with.
But, you may be able to specify a different refresh rate based on the ability of your video card. Right click on the desktop, choose properties, then settings, and advanced button. On the new window, click on Adapter, then click on the Display All Modes button. The default for 1024x768 resolution is 60Hz, but your video card may offer another frequency which may be compatible with the monitor.
If you are unable to see anything after the computer boots, restart in safemode, then make the changes.
Is this an older monitor? 1024x768 is an industry default mode / setting. I am surprised that the monitor doesn't like it.
Jun 22, 2010 | LG Flatron L1515S 15" LCD Monitor
Colour adjustment
first you do auto adjustment if it is not solved pl describe your problum in details
Jul 24, 2009 | ViewSonic VA702b 17" LCD Monitor
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor message
hello this is nichu ,your monitor is not supporting your cpu .hence you are getting the message "processing auto config message from screen display".either you have to change your monitor or you have to change your cpu.next time while purchasing the pc get the help your hardware vendor to check out the compatibility
Nov 04, 2007 | Gateway FPD1530 15" TFT LCD Flat Panel...
LG Flatron L1515S 15" LCD Monitor Logo
4,219 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
