Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
At the moment i am stayin in an apartment that needs a lot of work. the thermostat wasnt hooked up and was told the wires were there. i found wires and the old thermostat but there's only two wires. i then realized that i didnt have a clue and need some help. Please help its freezing outside and soon to be inside as well
  • 4 Answers
On a 2 wire heating control, the 2 wires would be connected to the "R" and "W" terminals of the thermostat. The thermostat is simply a switch that routes power to the different connections inside it for different applications. Power comes in on "R" and is sent to "W" when there is a call for heat.
Posted on Oct 02, 2010
Atwood furnace rv
try to jump the r and w where the t- stat wires are maybe bad t-stat
Jul 04, 2013 | Heating & Cooling
My regulator keeps blowing
Wiring looms for these are cheap enough on ebay, i suggest buying one and replace the lot, also check your fuses.
Mar 18, 2012 | 2003 Suzuki VL 125 Intruder LC
RTH221 honeywell thermostat install, hooked up blue wire from old thermo that hooked to C to o/b connection on new thermostat no work did I screw something up as old thermo will not work as well now. was...
maybe a blown fuse if it has one... if not then you blew the transformer...
Check on the circuit board in the furnace or air handler for a fuse...
if there isn't one... then you will need to replace the 24v transformer... they blow very easily...
heatman101
Aug 05, 2010 | Honeywell Heating & Cooling
How to put the green shifting wire back to the way its suppose to
the linkage from where it meet the car body to the shifter parts green ground worldaround
Mar 29, 2009 | 1990 Dodge Dynasty
Amp problems
The main thing that comes to mind is whether you've checked the in-line fuse on the positive wire. Most amp installations are supposed to have a fuse within 1ft of the battery terminal for just such a reason. Next, if you have a voltmeter of some kind (or know someone who does), check to see if you still have 11VDC-14VDC at the power terminals of the amp. If you do, then check the remote turn-on lead (which is supposed to connect to either your head unit or the ignition). If my memory serves, the remote wire should be high (about 12V) when the amp is being told to turn on and low (less than 2V) when it's being told to turn off.
Jul 29, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Honeywell thermostat Model CT87N4450 heat works but not air 4 wires coming in red, blue, green, white
I had the same problem and decided to take a chance and call honeywell customer support. I am shocked, they solved my problem! At least in my situation we found that the blue wire ran the compressor. Instead of hooking up to "blue" on the thermostat, we hooked it up to "white." It works wonderfully now.
Jul 02, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Wall oven again
Singed wires suggest electrical fault or excessive heat, i personally suggest you have the unit checked out by a professional to ensure your own safety.
Jan 22, 2008 | Ovens
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
