Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer is not working. seems like fridge isnt as cold as it should be
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Auto defrost seems to not be working because the drip tray is dry is it supposed to be like this or wet most of the time freezer is cold but not freezing and fridge isnt cold i have temp gaugers in both...
either un plug the fridge and let it defrost manually, or empty and flush out drain line with a hose or hot water. when it goes into the defrost mode, water should drip into the pan..
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer cold fridge isnt
freezer working,fridge not working,condenser fan ok, compressor running very hot.
Dec 14, 2011 | Whirlpool GS6NBEXR Side by Side...
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Please can you help me my fridge peezer FFA60 FUTURE fridge freezer isnt working right, my freezer is great but my fridge seems to stop & start altough the light is still on, if I turn off plug it...
that model number does not come up in my program, so I cannot give you any concrete advice. The fact that your freezer is great is a good sign, nothing major. Sounds like you may have a bad freezer fan motor, not blowing cold air down to the fridge section. but the fact that it is intermittent like that, you might have a faulty main control board. Without proper inspection, I cant say for sure.
www.FixMyFridge.net
Mar 08, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Mar 07, 2010 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Freezer cold fridge warm
clean the condenser coil in the back of the unit
Apr 20, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
