Question about Singer 7436 - INGENUITY
Singer 7436 beeps - not working
When I press pedal I can hear 3 beeps, but nothing happen. Mechanicaly works, when turn wheel, lights are on.
  • 323 Answers
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
Posted on May 28, 2008
  • cynthiagoins
    cynthiagoins Aug 17, 2012
    Where is the buttonhole lever you're referring to???? Please dont say the presserfoot.
By chance do you have another sewing machine, if so check to see if you have the wrong foot pedal attached to the ingenuity. I had the same problem and it was because I had the wrong foot pedal plugged in
Posted on Aug 20, 2009
2 Suggested Answers
  • 323 Answers
SOURCE: 7436 beeps problem
Raise your button hole lever which is near the presser foot.
sewman7
Posted on Jun 19, 2008
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Apr 08, 2017 | Bernina Sewing Machines
My singer ingenuity 7436 will not sew when i press the pressure foot the motor sounds but no movement
have you checked the knob inside the wheel on the right . If not tightened (hand tight) needle will not move.
Dec 11, 2014 | Singer 7436 - INGENUITY
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
The hand wheel & the overlock machine 14SH654 cannot move
so nothing is moving at all either by pressing the pedal or turning the hand wheel? Can you hear the engine humming or is the light working okay?
If yes, then this could be a gear failure inside the machine and not something easily fixed. Is this a oldish machine that has either had a lot of work or been sitting for a while? Has it been serviced at all in the past?
My Bernina 334D failed and it was a nylon gear in the main drive area which I had replaced but the dealer wasn't keen to do it, they wanted to sell me a new one. However, I checked with Bernina themselves that the part was available and how much, then talked to a local repair guy and he did the job for me. About 1/3 the cost of a new one though.
I'd suggest you take it to a Singer dealer and ask for a quote and find out if this is what has happened to your machine.
Mar 19, 2011 | Singer 14SH654
Sewing machine does not sew. Finished sewing something, turned it off, then turned it on a few hours later and it will not work. Light is on but nothing happens when the foot pedal is pressed. Took apart...
Call Singer at 1-800-4singer and ask for their advice, you do not want to void your warranty with not going to an authorized repair service if it comes to that. Good luck
Oct 07, 2010 | Singer 5050 Mechanical Sewing Machine
I was sewing some thick material and now I get 3 sets of 3 beeps, now when you press the foot pedal nothing happens
You probably need to clean out the bobbin case area and then check your needle to see if it's bent. I know when I sew very thick fabric or many layers... it sometimes bends the needle. Also make sure you're putting the presser foot down when you sew. Then see what happens. Let me know if any of this works or if you've already resolved your problem.
Sep 11, 2009 | Singer 2638 Mechanical Sewing Machine
Singer 7436 - INGENUITY Logo
595 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
