Question about JVC Car Audio & Video
I have a kw-xr616 unit im trying to install into my car, ive checked all the wireing and checked the cars wires via the web. the unit keeps telling flashing PROTECT, can i have some more reasons as to why this is happening. please thanks??
MrLard
  • 94 Answers
SOURCE: Anyone might know the wiring diagram for the cdx c680
does the harness look like this?
Posted on Apr 24, 2007
mixmaster
  • 626 Answers
SOURCE: wiring car sterio
Could not find your specific model.
But I found this on the Sony website.
9-pin wiring harness
16-pin wiring harness
Posted on Nov 25, 2007
DrElectrics
  • 199 Answers
SOURCE: Infinity Basslink 2
Follow these instuctions and piece together where you went wrong. Sounds like a wiring fault.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Feb 18, 2008
wdwbusiness1
  • 4 Answers
SOURCE: car stereo installation speakers
Yeah, rewire that.
Posted on Aug 19, 2008
jamesmac
  • 71 Answers
SOURCE: wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Posted on Sep 09, 2008
Im replacing the radio with an aftermarket, i have installed it with proper wiring harness but the new head unit will not turn on. any suggestions?
Go to the Crutchfield site and check just in case you are missing something. They probably sell the same radio and in a pinch you can call them and tell them you can't get it to work; someone should be able to help you out. They do offer great speakers and trim panels to make it look like a factory pro install too.
Mar 21, 2015 | 2003 Oldsmobile Silhouette
KW-XR616, No audio, no protect or mute lines triggered, bit suss about the R2S25400 power supply IC but can't find a data sheet for it, any help appreciated. ;)
Why do you suspect power supply IC? Check voltages before you take the next step. Have you checked the condition of the front board. If pushed on the Volume control by force, it breaks. send me your email ID if you want schematic.
Sep 29, 2013 | JVC Car Audio & Video
Tailights,Dashboard Lights Fuse Keeps Blowing Out
One thing to check and I have come across this a couple of times is that some factory stereos used a black wire for the stereo illumination, if you have wired the black (earth) from the new unit to this wire it will cause the fuse to blow, disconnect the earth from this wire and wire it directly to the vehicle.
Feb 23, 2013 | 1992 Geo Prizm
I have installed a jvc kw-avx726 and i just want to no which wire from the the head unit is the handbrake wire and also what do i need to make and answer phone calls through my cd player
http://books.jvc.com/booklist.asp?Model=KW-AVX706 This is a link to JVC support site where you can download the manual. However for a quick jump start. It is the LIGHT GREEN cable. Regarding the phone, reading the manual will be your best solution. Plus it is good to have a manual around. dreamsystems
Feb 08, 2011 | JVC KW-AVX706 Car DVD Player
My electric bill soared last month and this humidifier is the only new item I have plugged in. Can you tell me what the kw usage is for running this on both high and low settings??
The humidistst sounds like it is not regulating the humidty. The system probably is not shuttung off. Depending upon the humidistst setting.Check wiring from the humidistat and humidifier. Try to locate a installation mqanual fir the unit via the internet.
Jan 26, 2011 | Vicks V745A 1 Gallon Humidifier
JVC KW-AVX710 not save. after switch off the car .when start it again all settings become to default
If your unit is not maintaining it's memory, it may be associated with the lack of a constant 12 volt power source. Test the units yellow wire, it should rest at 12 volts with the key in all positions; off, acc, on/run, start. This yellow wire should be connected to the vehicle's battery wire. Also, test the red wire. This wire should be connected to a switched 12 volt power source. It should read 12 volts with the key in accessory and on/run only. If you used a vehicle specific wiring harness to complete the installation, the wires may be switched in the harness. It's not a common issue but, I have seen it happen.
Dec 04, 2010 | JVC KW-AVX710 Car Monitor
I recently wired a eonon e1091 into a 2007 silverado classic. i used a scosche wiring harness that allows me to keep my chimes. everything works fine but when i turn the truck off, theres still power...
It's called delayed acc. power. It should shut off as soon as you open the door. Unless the red stereo wire is hooked up to constant power. You may need to check with a test light.
Oct 31, 2010 | Car Audio & Video
My electric furnace keeps tripping the breaker , it will run for about five or ten minutes then trips.
If you dont have an ampmeter it is hard to tell whats going on. First check the breaker and see if it is getting hot. If so turn off power get a screwdriver and check to see if wire are tight on the breaker. Loose wires cause breakers to trip. If the unit has ran before and it has not tripped the breaker and it hss just now atarted replace breaker but do not put a larger one in. Check the size of your heat strip in Kw or what they call for on the size of the breaker. 10 kw no larger that 60 5kw no larger than 30. 15 kw has a 60 amp and a 30 amo circuit. Let me know whats going on.Rus
Dec 07, 2009 | Refrigerators
06 cobalt stock system hook up
I cant really assist in this matter but I can let you know that I have a system in my 2006 Chevy Cobalt and that I have an aftermarket cd player installed. I had to pay $130 for a special adapter for it to be wired into the system because GM's newest idea of installing the stereo and airbags on the same wire scheme, is kind of a dumb idea.
Jul 02, 2008 | 2006 Chevrolet Cobalt
Car Audio & Video Logo
499 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
