Question about Ovens
We have a Westinghouse Kimberley 509 stove. We can't control the heat on the hot plates, they just go full hot.
2 Suggested Answers
  • 447 Answers
SOURCE: hot plates go red hot even on low setting on my
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
Posted on May 16, 2010
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
Need to download user manual
It could be one of these:
https://www.westinghouse.com.au/search/?q=pak509
Nov 20, 2015 | Westinghouse Kimberley 509 Ceramic Oven
Westinghouse kimberley 509 upright oven. How to reset time of day on the clock ?
Press the "clock" button. Either enter the time digitally or use the "up" or "down" arrow buttons to scroll to the correct time, then press the clock button again.
Sep 17, 2015 | Ovens
Can't control the hot plate temperatures, always come on at full power.
I would say thermostat but I am not sure about this one.
Aug 26, 2014 | Ovens
Westinghouse 668w
Sounds like you are only getting half the power to your stove, first check your breaker for the stove,turn it off and then on again,one side off the breaker may not be making a good connection giving you only 110v instead of 220v which is why you will have lights and no heat. If that does not solve the problem and you are comfortable working with electricity shut off the breaker, unplug the stove and remove rear access panel where the cord goes into the back off the stove and make sure all 3/4 wires are securely connected, that being done and it still does not work you may have a bad breaker or connection in box or a faulty outlet.
Apr 07, 2014 | Ovens
When using grill knobs get to hot to turn stoves 600 sidl
you are missing the heate plate that stops the knobs from getting hot go to ebay and put your model in and look for heate plate or some thing like that
Oct 12, 2012 | Ovens
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Need part number for westinghouse kimberley 501 oven element PAJ501R
WESTINGHOUSE PAJ501R not working at all. Fuse and safety switch all ok.Does this oven have an internal fuse? thx stephen
Aug 28, 2010 | Ovens
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
May 16, 2010 | Ovens
Ovens Logo
519 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
