Question about Canon LASER SHOT LBP 3300 Printer
Have a canon lbp330 printer. i see a tiny bit of paper stuck inside. how do i open the printer and remove it?
  • 41 Answers
Any paper jam indication? Other wise leave it. No problem.
Posted on Mar 02, 2011
Paper jam but no paper
FIRST UNPLUG IT, GET A FLASH LIGHT AND LOOK WHERE THE ROLLERS ARE. YOU WILL FIND TINY PEACES OF PAPER STUCK INSIDE. USE TWEEZERS TO REMOVE IT.
Feb 11, 2012 | Canon Pixma MX410 All-In-One Printer
A paper got stuck while printing i tried 2 pull it out, but it got teared.. nw it shows warnings.. jst jammed.. dono wat 2 do??
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!
Concerned: Angel Bird
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
The paper gets stuck on one side and will not go through the printer
There's probably a tiny bit of paper stuck somewhere in the paper feed path. To start with, open all the covers that can be opened and inspect for debris. You could try using a can of compressed air, to blow out any junk you find.
Failing this, the printer may need to be disassembled and inspected for broken gears, pickup rollers, etc. That's not really a DIY job, so you may wish to consult your warranty.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
My PC 745 comes up with an error code of a paper jam but I cannot find any jammed paper. Any suggestions.
completely remove the paper cassette and look for A SMALL PIECE OF PAPER stuck inside the machine in the paper path. Also use a flashlight to check for tiny bits of paper in the exit section of the machine where the fuser (hot) rollers are.
Dec 16, 2010 | Canon PC-940 Black and White Copier
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Displays paper is jammed message when there is no
There must be a bit of paper torn off and stuck in the sensor for the paper jam on the Output side of the printer. Look for a tiny bit of paper where one ought not to be.
Sep 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-12
May 26, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon LASER SHOT LBP 3300 Printer Logo
110 people viewed this question
old marine
old marine
