Question about Twinhead SlimNote N12PI Notebook PC
Operating sytem not found, what are the BIOS settings
  • 304 Answers
Hi.
As the Computer is displaying an error message "Operating System not found", you may perform a BIOS reset and check if the issue is resolved.
1) To reset the BIOS, boot the Computer to the BIOS.
2) Once you are in the BIOS, please try pressing the F9 key.
3) The F9 key should be the shortcut key to reset the BIOS.
4) However, you will also have the option to reset the BIOS in any of the tabs in the BIOS main menu.
Please try performing the above steps which I have mentioned and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Posted on Oct 02, 2010
Boot problem with acer travelmate 290 model CL51, only bios working.
if a computer boot up only until the windows xp screen not on windows environment...usually it is because of corrupted system...
your pc will never boot until the logo if there is a problem in your video card,sound card,memory or power supply...
so i suspected that there is a problem in your operating sysyem..try to run system restore if you have...
if not you need to format your operating system so that you can use your laptop again...
note: i have also experienced a problem with boot until the windows logo, but i found out that the problem is not the operating sytem...i found out that my client's capacitors in his motherboard are damaged...maybe due to over use or improper cooling system...if you can check it that's much better so that you can prevent waste of money...
Feb 22, 2010 | Acer TravelMate 290LCi Notebook
Cant reload operating sytem
you need to set up bios so laptop boots from cd drive not hard drive when you have done this press f10 to save you will be asked press any key to boot from cd rom make sure your operating system disk is in drive windows will do the rest.
Nov 13, 2009 | HP Compaq Presario 2145US Notebook
Boot won't read
Operating system not found. Check hard drive for loose connection power and interface. Reseat it to be sure (power cord disconnected and unit totally turn off before you reseat it).
Go to Bios setting check whether hard drive is been detected or re-detect it to refresh. If harddrive is not detected. Check again for loose wiring. If now detected, reboot it should until the end of operating system loading.
If it say again " requires sytem disk" ,corrupted OS --- repair or reinstall.
Apr 08, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I want to put a 250 gig hard drive in a dell d600 but the bios a16 dont support that much what do i flash the bios with I know they do it as for they are for sale all over ebay with 250 gig.
Dell D600 have EIDE interface not SATA.
If you found EIDE or PATA interface for D600 with 250GB....when you install it divide the partition into 2.(100GB for windows sytem) and the rest will be your second drive.
here is the link for your BIOS upgrade:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R103802&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2816&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=2&libid=1&fileid=133833
Systems: Dell Latitude D600 Series
Version: A16
Build Date: 06/29/2005
The following updates were made to the A15 BIOS to create the A16 BIOS:
ATI Radeon 9000 Video BIOS version is 8.002.007.019
Issues Fixed:
Issues Fixed:
1. Reduced audible pop sound during POST.
Enhancements:
1. Added support for new processors.
2. Update Broadcom 57xx PXE code to support newer hardware revisions.
The BIOS release has been validated on the following operating systems:
1. Microsoft Windows 2000 ACPI
2. Microsoft Windows XP
Mar 16, 2009 | Dell Latitude D600 Notebook
Booup of a custom system.
disconnect all hard drives except the one with your operating sytem and try that. You may have something hooked up wrong but you need to rule out other problems..can you see all the hard drives in the bios?
Jan 19, 2009 | AMD Athlon 64 4000+, 2.4 GHz...
Problem related to bios setup
it doesn't matter. if you are running 32 bit operating ssytem. you can get majority of the hardware drivers.
however, if the operating sytem is 64-bit, you can't run it on a 32-bit machine. that is what determine by the BIOS.
since you have install the sytem and it seems running fine. I would just leave it alone.
Nov 13, 2008 | Computers & Internet
K8n neo ms-7030
change the first boot device,
go to the bios option by presing del button
ther select your first boot device like hardisk n second is cdrom the f10 for save configuration and press k and check it
Oct 18, 2008 | MSI K8N Neo-FSR Motherboard
Windows XP Passwords
Well, the best way to setup security is through a BIOS password. This bypasses any operating sytem and doesn't allow any user interaction until the password is entered. Also, a user cannot edit anything in the BIOS without a master password.
Most BIOS systems can be entered by pressing delete during the initial startup of the machine.
As for windows XP, the only true security it has is the startup password. Which is setup through the users menu in control panel. You can, however, setup advanced security and disable many abilities of other users using the Administrator account on your operating system.
Sep 21, 2008 | Acer Aspire 5610-4648 Notebook
Open Questions:
Twinhead SlimNote N12PI Notebook PC Logo
163 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
