Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
At first my washing machine just started out by making a very loud "thumping" noise at the end of every spin cycle, and it just go progressively louder. Now, the noise isnt quite as bad, however, the water is not completely draining from my machine, and there is a slight burning smell at the end of the spin cycle. it seems to me that the spin cycle it self isnt causing the noise, but when the cycle has ended and the machine's drive has disengaged; thats when the noise really gets bad.
Please help!! I am enlisted Navy, so $ is always tight, so just buying a new machine is out of the question...Im really hoping this is just something I can repair on my own.
Thanks very much for your time,
Tony
  • 3 more comments
  • AJGrosso904 May 26, 2008
    its definitely a thumping noise. and when the machine is off, i reached in and spun the basket by hand; when i spin it one way, there was no noise, but when i spin it the other way, it makes the noise each time i complete a revolution.
    Tony
  • AJGrosso904 Jun 02, 2008
    Rgr....Thank you very much for your help and your time.
    Much Appreciated
  • Buck Whyte
    Buck Whyte May 11, 2010
    ok shoot me the make and model number
  • Buck Whyte
    Is it a grinding or a thumping.. It could be something caught in the impellor for the pump, or it could be the tranny going out..
  • Anonymous Mar 23, 2014
    heard loud noise when spinning, burning smell, and pieces of plastic found in washer
  • 413 Answers
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
Posted on Jun 01, 2008
2 Suggested Answers
  • 686 Answers
SOURCE: loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Posted on Apr 06, 2009
Loud noise while running
Hello. Did you get an answer to this inquiry. Mine is doing the same thing. Smell of burning plastic; continues to fill and drain at the same time?!! I have to manually shut of water to stop the water and then manually set to spin so it will drain!
Mar 22, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
SMELLS LIKE SOMETHING IS BURNING WONT AGITATE OR DRAIN
Sounds like a belt has gone bad. Tip the waher toward the wall. You might see two belts. If you do not, get me you model # and I will see exactly what nodel you have.
Please let me know if I can assist you further
Thanks
Vic
May 16, 2009 | Washing Machines
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Burning smell (electrical) from my washing machine
possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Oct 03, 2008 | Smeg WD16BA Front Load Washer / Dryer
Loud noise and smell
It would help to know the brand and model number of the washer. If it has a belt that also runs the pump, something may have gotten into the pump during drain and locked the pump causing the belt to slip.
Oct 07, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
431 people viewed this question
Dan Webster
Dan Webster
Sal De
