Question about Cycling
Phillips kiddicarrier 202 manual - Cycling
5 digit number for phillips tv
The 5-char Direct Philips Magnavox Universal Remote Code Entry is: PM335.
the Phillips tv (3 digit) code choices are: PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
Hope this helps! (Here's the link to same...)
Jul 09, 2014 | Televison & Video
Code for philips hdtv
These numbers are all the possible codes for a Phillips TV. 002 009 020 109 122 202 209 210 222 310 322 402 408 422 508 510 807 822 901 914 917 919 922
May 26, 2013 | Televison & Video
Hi I havr 42inch flatscreen model 202 Phillips tv .When I turn it on it has no sound.Somedays it does have sound but most days nothing
The audio output section and the speakers to your TV should be checked. Contact any experienced service technician, as fault finding to audio output stage is a skilled work.
Jul 02, 2012 | Philips Televison & Video
I have a u r c 4021 i need to program for a phillips tv
Philips TV code might be one of:
Test to find out which works best for your TV. Look in your TV manual for information about remote control codes, it may tell you exactly which is the right code. If you want more help, post another request on FixYa with the exact model of the TV.
All the best.
Dec 03, 2009 | One For All URC-4021 Remote Control
I lost my code to my phillips universal remote 35/80 can u help
try these number
copied off of site
Feb 01, 2009 | Philips PM435S Remote Control
Need phillips magnavox code to put into dish network remote
I'd be happy to help you with your request. The codes you are looking for are:
If you are satisfied with my assistance please use our rating system to evaluate my service. Thanks for using Fix Ya!
Jan 26, 2009 | One For All URC-3021 Remote Control
I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Philips Magnavox Learning Universal Remote
202 Paper Jam
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
Cycling Logo
243 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
