Question about Whirlpool Washing Machines
The display on my whirlpool FSAH651 says" PE".. and doesn't work...
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
Pe error on whirlpool washing machine
Check the motor brush they surely are dirt you can also clean the collector where the brushes lays on
Jan 28, 2014 | Smeg WDI12 Front Load Washer / Dryer
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
My whitemagic machine allows me to select a program and when i press the start button it shows PE error. This is happening since 2 days now.
This is a Pressure Sensor Error.
Remove the top of the washer. The pressure is usually located at the top. It will have a plastic tube about 5/16 in size. Remove the tube and blow down into it to try and clear any blockage. If that doesn't work replace the pressure switch.
Oct 27, 2012 | Whirlpool Washing Machines
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I have whirlpool 650d, Its a new one. I am seeing PE error in the display, quite often. Due to this one hour washing takes, 2 hours, 3hours. How do we get over this error. Voltage in my area usually...
Phase error does mean low current only a current rectifirer will solve this will keep voltage regulated dipending on the load of machine it could be expensive to buy a proper voltage regulator for it
Sep 17, 2017 | Whirlpool Washing Machines
Washing Machines Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
