Question about Motorola Mobility RAZR V3
RAZR V3 WITH PLANATRONICS BLUETOOTH
DEVICES PAIRED OKAY. WE WERE ABLE TO USE BT CAPABILITY ONCE WITHOUT PROBLEM. AFTER THAT THE PHONE CONTINUALLY DISCONNECTS IMMEDIATELY (5 SECONDS APPROX) AFTER CONNECTING. ALL IS CHARGED. TRIED REMOVING FROM PHONE AND RE-PAIRING. CAN'T SEEM TO SOLVE THIS. ANY SUGGESTIONS?
    Brigadier General:
  • 7,752 Answers
Try a master reset of the phone or delete all BT devices in your list....hopefully this corrects the issue
Posted on Jun 02, 2008
Bluetooth connection
You may try deleting your phone off of your car and re-pair
Jan 12, 2015 | Toyota Camry Cars & Trucks
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
Jan 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Phone won't stay paired w/bluetooth
may be software problem..or make sure that your phone is visible for other devices..
Dec 13, 2008 | Motorola Mobility RAZR V3
Mazda bluetooth connection
delete all bt devices in your phone then try again
Oct 01, 2008 | Motorola Mobility RAZR V3
Unaable to connect bluetooth to phone
make sure the BT headset is fully charge.
  • press and hold the power button on the headset it will have a constant blue light indicating it is one
  • activate the bt in menu/settings/connections/ put the phone to search for the h/set once it have find it , it will ask you to enter the passcode which is 0000.
  • now you should be paired to he headset
Jul 01, 2008 | Motorola Mobility RAZR V3
Bluetooth unable to power up
The bluetooth module on the phone is broken or the phone has an invalid configuration that prevents it from detecting the bluetooth chip.
Try to reflash the phone, if that doesn't work, the main board need's to be replaced.
May 05, 2008 | Motorola Mobility RAZR V3
I can not get my bluetooth motorola 350 ear piece to work with my Razr
My suggestion:
First take your BT device (Not the phone), and hold down the pwr button until the light stays on constant (this is "find me" mode for most BT devices like headsets).
Next on your V3 goto your Settings/Connections & select Bluetooth, then scroll righ (or select options) to search for your device.
Once your device shows up in the screen selct it by hitting the center of the nav key and it will ask for a passkey wich is normaly "0000".
You should then be paired.
Apr 25, 2008 | Motorola Mobility RAZR V3
Auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
maybe while pairing up the new phone you have turned down the volume on the earpiece?
Nov 28, 2007 | Motorola Mobility RAZR V3
Bluetooth headset
you need to turn on the headset and to order the phone to search for BT devices.
May 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
