Question about Garden
I need a schematic drawing for a Poulan 445 PRO Chain Pole Saw
  • 3,740 Answers
Go to this page:
http://www.jackssmallengines.com/help.cfm
Choose
1. Poulin
2. Poulin Pro
3. Pole Pruner
4. Gas
Then select either PP446E Type 1 or Type 2
If you need parts for the attachments then choose attachments and find yours.
This will get you straight to the engine:
http://www.jackssmallengines.com/help.cfm#AssemblyPartsSearch'model_3hfQcmydHGxAIk/GvlHpyA=='assembly_/GhQJfqNUvNbNmAjA03NAg=='brand_ahjxOQtsOoMBNqd6InjYkA==
Thanks for choosing FixYa.
Kelly
952-051549
Posted on Oct 02, 2010
How do i remove clutch assembly on a poulan 445 pole saw ?
First you need to remove clutch drum. Inside the center is a trox that need to be loosen to remove it. Then you will to remove the spark plug so you block the piston movement using a piston stop or fill the cylinder with rope. The itself is left handed threaded and there will an indicating arrow on it as which way is off.
Jul 29, 2014 | Poulan Garden
How to remove clutch assembly on poulan 445 pole saw ?
remove the cover, the chain & bar, you will have the chain driving gear and clutch housiing exposed. The nut holding them on the driveshaft is REVERSE THREADED so use a appropiate ring spanner fit it to the nut and with a hammer sharply STRIKE it in an anti clockwise direction. the nut will come loose and you may slide off the clutch.
How do I replace starter rope on a poulan 445 pole saw?
I have pulled out the spark plug and stuffed some rope into the cylinder. The piston will then not be able to travel the full distance and will keep the clutch from turning. Use rope that will not shed particles. This will let you remove the clutch bell.
Why pole saw wont saw?
There could be a couple of reasons why your saw won't cut.
The first thing I would check is to make sure you have your chain facing the right way.
The chisel edges should be facing forward, or in the direction the saw chain is rotating.
If this is not the problem, then I suspect the chain itself is dull.
Jul 08, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
Jul 13, 2011 | McCulloch 10" Electric Pole / Chain Saw
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Jun 16, 2009 | Poulan Garden
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
259 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
