Question about Kodak Office Equipment & Supplies
We have a Kodak 700. After years of not using it turned it on tonight and there was very loud screeching noise. Is it the fan? Can it be repaired?
I am having a simular problem The fan is rubbung on the metal housing.
Posted on Nov 28, 2011
    President:
  • Kodak Master
  • 412 Answers
The KODAK Carousel 700 was manufactured from approximately 1964 through 1972.
The problem you describe is that the motor is spinning but one of the drive belts are not moving. That requires disassembly & complete service. Look for an Authorized Service Dealer in your area.
Posted on Nov 04, 2010
My 2003 dodge durango keeps overheating , i just had new radiator put in and it started overheating again but now it is overheating with a very loud screeching noise like a belt sound what could be ca
as for noise will have to inspect under hood,could be fan or belt or pulley ,water pump .these are some things it could...My suggestion for overheating is replace thermostat. If your car has electric cooling fan then it may not be working..turn defrost on and if fan kicks on then fan motor is good..Now this does not mean that fan is working properly because fan is controlled by heat sensor switch that kicks fan on when motor reaches heat range......Things i would have checked....hope this information helps and good luck and Please rate my post...
Aug 17, 2012 | 2003 Dodge Durango
My dryer is making a loud screeching noise when I turn it on, it is only 3 years old.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Whirlpool WED9200SQ Electric Dryer
Tempstar a/c condenser screeching noise
Could be the fan motor's bearings. Try turning the fan by hand to see if spins freely or is tight. If it's tight you can try oiling it but that may not work for long.
May 30, 2010 | Heating & Cooling
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
The fan clutch was replaced but the same noise which sounds like an airplane taking off is still present when accelerating at any speed. Does the fan motor need to be replaced also?
Could be your belt tensioner is worn out and needs replacing, common for a 10 year old vehicle. Is it a loud squeeling noise? if so then it's the belt slipping and rubber on metal pullys is a loud screeching noise
Aug 05, 2009 | 1999 Ford Expedition
Fan motor has loud screech.
Check for oil ports on motor. Usually red or yelloe plug in caps. No more than 20 drops of oil. I usually use sewing machine oil.
Apr 26, 2009 | Heating & Cooling
Aprilaire 760 furnace humidifier makes a loud screeching sound.
A bad circuit board should not make any noises. A bad solenoid valve could make a loud buzzing noise. If the noise is a squealing noise then you have defective bearings in the blower motor.
If you disconnect the low voltage wiring from the solenoid valve and you still hear the noise, then its not the solenoid valve.
Apr 06, 2009 | Aprilaire 700 Humidifier
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
