Question about Whirlpool Gold® GC5SHEXNQ
Fridge door My product in the fridge door does not seem to be cold enough, I have had to cartons of milk go bad well before their due date. I have had this fridge for 8 years and have always stored milk in the side of the door. Please help this guy out.
  • 828 Answers
Have you cleaned the condenser in the eight years? If not it is due time. Some are located in back of the toe plate under the door. Others are located in back behind a removable panel. Be sure to reinstall the panel after cleaning as it is necessary for proper air circulation for the system.
Posted on May 26, 2008
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Why do my fridge freeze up
as silly as it sounds it mite be because setting to cold or not enough product in fridge. i use to store all my milk at top of fridge and it used to freeze. put milk lower down and now problem. mite be a different case for u.
Jan 21, 2013 | Refrigerators
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
My fridge is not cool enough why My friend has a Bosch Fridge freezer he said that the freezer is working ok but the fridge is never cool enough a carton of milk will last till the following morning and...
Have you turned up the dial on the inside?
If thats not it then it needs re gassing or probably cheaper re-placing.
look for any controls and turn them up first !
All the best !
Sep 22, 2009 | Refrigerators
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Samsung RS21DPSM American style fridge. The problem is with the fridge side of the thing. I noticed the other day that the milk didn't seem as cold as it used to - so, what with the hot weather I...
We have a similar problem ! bottom 2 compartments are cold but the rest including the door is not ! An engineer has advised us that due to excessive opening of the door we have caused an ice build up of approx 5 inchs at the back of the fridge! he has told us to turn off the whole unit and allow it to defrost and he will be calling to service it on Fri 2nd jan 09 .
Jul 29, 2008 | Samsung Refrigerators
Refridgerator/Freezer will not get cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Refrigerators
Check to see if the refrigerator is clean at the condensor at the bottom or at the top of the unit. All fans running inside and outside the unit? Door gaskets sealing tightly. Put a dollar bill between the door gasket and cabinet and clost the door. Slight drag ok. No rsistane, bad gasket. No solution at this point, call for service.
May 04, 2008 | Magic Chef CTF2125 Top Freezer...
Whirlpool Gold® GC5SHEXNQ Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
