Question about Jensen Car Audio & Video
JENSEN Parts How to obtain the CARD 123010020494 and the Flex cable that connects card to the LCD screen Tks - js
  • 1 more comment
  • jsem May 27, 2008
    Model is VM9512 DVD Receiver and
    the cable is the one that connects the requested card to the LCD screen. Tks - js
  • jsem May 29, 2008
    The flex-cable site not help.
    Need to know where I can purchase
    JENSEN receiver parts
    tks - js
  • jsem May 30, 2008
    TKS FOR YOUR EFFORTS
    HOPE YOU'LL BE SUCCESSFUL
    JS
    Brigadier General:
  • 3,614 Answers
may i know the exact model # of the unit, & please do add more info regarding to this problem..
thank you
Posted on May 26, 2008
  • 2 more comments
  • micromaster
    micromaster May 27, 2008
    hi thereagain,
    may you check out in this SITE to see if the product your searching was here available..
    Thank you
  • micromaster
    if my info/idea helps you, please kindly rate my solution.
  • micromaster
    micromaster May 29, 2008
    ok.. i'll see where you can get one..
  • micromaster
    micromaster May 30, 2008
    try to place an order on this site..
    let me know again
Red and yellow horizontal lines on the last third of the screen
3 Options
LCD damaged
Flex cable from MB to LCD
Graphic card damaged
First try to connect the laptop to a external screen...its ok???
Remove the lcd and try another one...its ok???
If not....change the flex....its ok?
If not...only one option...graphic card (GPU)
Feb 26, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Motorola RAZR V3 LCD SCREEN went blank - black screen
The LCD flex connector is very sensitive. 4/5 of the RAZR screens I see go out are due to a loose flex connection. It's super easy to fix it. Take off the battery door. There are two T6 screws. Take them out and pop off the bottom of the phone. There are two flex cables: one for the keypad, the other for the screen. Connect the flat cable (screen cable) first. Then connect the bent (keypad) cable. Put back together. Voila.
Aug 16, 2007 | Motorola Mobility RAZR V3
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Oct 26, 2012 | Computers & Internet
My acer 5735 lcd screen has turned red its not the lcd flex cable.everything else is working fine?
It can only be a few things, you checked the cable, I assume you've installed the latest drivers. It's either the LCD itself, your graphics card itself, or my personal guess the inverter card (hope for this because it can be replaced). I'd suggest looking up about your models video inverter card and see if anyone else has had this problem. If not I'm guessing your LCD or graphics card are failing at the hardware level. Hope this helps out and thank you.
Jan 07, 2011 | Acer Computers & Internet
Screen remains dark
Wires connecting the TFT to the motherboard is most of the time to be blamed... It might be backlight inverter... I would suggest you to consult a company personal...because both require opening up the laptop.
Aug 04, 2009 | Compaq Presario 700 470024-192 Notebook
Acer screen is black or blurry
If you've connected an external monitor to your computer and the image is coming up fine then that means your video card on the motherboard is good.
The only other parts it could be is the LCD Flex cable that connects to the LCD screen to the motherboard, the LCD Inverter that powers the LCD screen or the LCD screen itself. Usually you can find a used screen that is complete with all those components on ebay.
Jul 30, 2009 | Acer Computers & Internet
Screen not working properly.
It could be the video card built onto the motherboard or the LCD Flex Cable running from the motherboard up through the hinge to the LCD panel, or possibly the panel itself. It could even mean the Flex cable has partially dislodged from the LCD connector.
Test first by attaching an external monitor. If you get an image externally then the video circuit is good. If not, check your warranty and have it serviced professionally as it would mean a motherboard repair or replacement.
If it is the Flex cable or panel, you may still want to have it serviced depending on your level of expertise. Removing and disassembling LCDs is not very difficult with this model, but it could be challenging if you've never done it before.
Dec 30, 2008 | HP Pavilion dv6000z Notebook
My LG Rumors screen is pixeladed and it keeps flashing, turning on and off. When I slide it open it sort of works, but then at messes up again. Now you can't see the bar on the bottom of the screen that...
This is probably a bent pin in you flex cable to the lcd or a poor connection,you will have to open the phone up at the lcd usually 4 screws around the lcd im not familiar with the model you have but this is a general problem with cell phones,after you get it open you should see the flex cable connected to the lcd disconnect and inspect the connection pins the gold looking metal parts if all look the same plug back in the cable making sure its in good and try it out,if this does not work your flex cable may be worn out and since im not familiar with that model i cant tell you how to repair it,well good luck
Sep 24, 2008 | Lands Phones
Car Audio & Video Logo
65 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
