Question about YouTube Videos
As soon as i open you tube site ,it quickly shuts down within two seconds....what can the problem be???
  • 106 Answers
  • try a different web browser
  • if same happens, then update your adobe flash player here:
http://get.adobe.com/flashplayer/
Posted on Oct 02, 2010
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
Our Rinnai Avenger 25 automatically switches off within 1 minute. When we press the on button, the unit starts with a green light on the "ON" button but within seconds, the light turns to red and soon...
Did you get any error codes? Press on/off button twice to reset heater or
press both the Up and Down buttons simultaneously for 3 seconds
It can also be a faulty temperature sensor, this would need a service call...cheers
Jan 21, 2018 | Rinnai Vent Free Gas Heater/
Latitude D830 starts then shuts down quickly.
1. Make sure you are plugged into A/C.. Your battery could be running low.
2. Make sure there is nothing blocking the heat vents. This symptom is typical for overheating processors.
Mar 17, 2013 | Dell Latitude D830 Laptop Computer PC...
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
The computer suddenly shut down & will not re-boot. On turning on there may be a few seconds to allow option of opening up in safe mode which is applied but within a few seconds the system shuts down...
Bad Power Supply.
Weak voltage power rail.
One of the leading causes of computer failure.
Replace the Power Supply.
[The next cause of failure is the computer is dirty inside, as well as inside the Power Supply's case.
Dirt, dust, etc, takes a Power Supply down quick ]
Need guidance of how to replace your Power Supply, or guidance in finding a decent replacement Power Supply let me know in a Comment.
Regards,
joecoolvette
Dec 02, 2010 | Packard Bell Computers & Internet
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
Ps3 freezes and shuts down after 20 seconds after powering on, what could this be?
I have the same problem. When it is turned on it shuts down within 30 seconds and I need to disconnect the power cable again before it can be turned on (and again shuts down after some 30 sec.)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Power to the mobo
Without having the specs on the motherboard or knowing how old it is, it's difficult to say if it is beyond repair. Although my experience with computers shutting down that quickly while attempting to boot have been a problem related to processor overheating. Processors get very hot within seconds of powering on. If the processor cooling fan or the thermal paste is not working as intended the system will shut down quickly. You may want to check those two possibilities before purchasing a new motherboard.
Nov 19, 2008 | FIC AM 37 Motherboard
Compaq MP2800 Lamp powers down after a few seconds
Hi Wayne
It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
Mar 22, 2008 | Compaq MP2800 Multimedia Projector
YouTube Videos Logo
121 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
