ORGINAL SETTINGS MONITOR
MY KIDS MESSED WITH THE SETTINGS ON MY KDS XF7B MONITOR AND NOW MY SCREEN IS ALL SCREWED UP. I TRIED RESET ON THE MONITOR AND THAT MADE IT WORSE. IM RUNNING WINDOWS XP PRO.
CAN YOU PLEASE TELL ME WHAT THE SETTINGS SHOULD BE.
THANKS DEBBIE
  • 2 more comments
  • kdoodle420 Jan 28, 2009
    i have the same problem .. my kids messed with the knob on the front messing up everything and when i tried to fix it just made it worse .. i have no clue what the settings should be .. i tried to reset it and it is telling me "cant reset" .. i dunno what im supposed to do here but my screen is SCREWED!!! someone help please????
  • tiffany_b17 Feb 07, 2009
    my daughter messed with all my settings and now i don't know where they are all suppose to be at.. i am running 32 bit color and 1280X796 or what ever the resolution is suppose to be, but i can not fix the monitor settinfs
  • Anonymous Mar 07, 2009
    my LG STUDIOWORKS 563N has a problem that its h position and h size is not working screen goes horizontally enlarged.
    thanking you,
    danish.ariba@gmail.com
  • Anonymous May 21, 2009
    hey xerick if you dont know how to do please dont answer nothing..., what a waist of time
    Scholar:
  • 139 Answers
Now check on the monitor setting u should see some button like disguse or some thing select that option and it would return factory setting
thank u
Posted on May 26, 2008
My tv turning green all of sudden Is there a way to reset it back to it orginal colors
If tv is Sony KDS-R60XBR1 as shown in question headings then it is problem of optic block (light engine) that needs to be replaced, it is hardware problem that wont get solved by resetting. Optic block is expensive part and qualified tv tech is required to replace it.
If tv model number is different, please post it to provide you info about problem.
Thanks.
Mar 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
K226WDB Monitor: I need to get the cover off my Kds K226wdb monitor...
You have to use thin flat blade screw driver to crack open the case, starting ta the bottom edge of the case and then work your way around. You can also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | KDS K226WDB Monitor
How do I return my KDS USA monitor back to factory settings for color?
The KDS has an 'OSD' ("on screen display").
Press one button on the front of the KDS to activate the OSD, and navigate through its various menu-items, to find the "reset" control.
Apr 16, 2010 | KDS K22mdwb LCD Monitor
I have a sylvania flat screen monitor. It is a flat screen but only the screen the back is normal. My kid was playing with the monitor settings through the menu on the monitor. Now it is all screwed up....
Inside the menu on the monitor, you should be able to easily find a Factory settings reset option. This will restore your original settings. If you still have trouble after this, then your problem is more complex than just settings. Let me know.
Mar 31, 2009 | Sylvania CW902 19" CRT Monitor
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
I can't figure out how to adjust the screen position on this monitor!!
rotate the button don't push it it is the degaussing (magnetic remover) that you are pushing, just rotate the button and you will be able to adjust the settings.by pushing the button when you get to the item you want to select
Apr 30, 2008 | KDS Visual Sensations 7 (White) 17 in.CRT...
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Computers & Internet Logo
886 people viewed this question
David Payne
David Payne
