Question about Philips PET702 Portable DVD Player
No Disc Found
My player will no longer read a disc of any kind. It makes a little noise and says no disc. I bought it in December. How can I fix it?
  • 139 Answers
Lose it and get the lense cleaned if the problem continues then replace a new one
than k u
Posted on May 26, 2008
The CD player will no longer recognize or play discs - or it takes ages to engage and play the disc. I think the laser is warn out. Is it replaceable, and is it cost effective to do this? Thanks, Ralph
I have the c521i with similar problem. It will play discs most of the time and sometimes can go for an hour or more before hanging up. Sometimes the disc is spinning and the laser is moving up and down (clicking) trying to read data. Sometimes the disc will stop spinning.
The replacement laser mechanism is a Sony KSS-213C and can be found by a few resellers on ebay for between $10 - 26, and also online at stores like MCM Electronics. This assembly has the laser head, gears, everything that needs to be replaced. I should get mine in the next few days. I also bought the 16 pin flex ribbon cable that is about 8 inches long that connects from the laser and goes into the circuit board. With basic DIY skills, this is a simple fix. A little care and effort is required on the laser assembly. I am told this will fix and will report back as soon as I get it installed and can verify it works.
Jan 01, 2011 | NAD C521 CD Player
Putr dicic in makes rubbing noise wont play
The laser and mechanism are out of alignment. Did you drop this or some how, did it take a blow of some kind? You can take the cover off after you unplug the machine and check to see if something is causing the disc tray to be out of alignment. If the machine can't read the disc for some reason or another it will also make a bunch of noise while the laser is moving trying to pick up the starting point on a disc, Have you tried more than one disc?
Nov 18, 2010 | Sony DVP-SR200P DVD Player
I bought a new LG Blu-ray player at Best Buy in December of 2009. For the last couple of months (begining in May of 2010) I'be started experiencing my player not wanting to play a large majority of my...
two of the main problems associated with players are their motor's and their lens. the lens emitts a light which reads the image off the disc, if the lens is going bad then that lighting signal isnt as strong as it should b and it wont be able to read the disc. on the other hand if the motor spinning the disc is spinning to slowly or it starts but doesnt continue spinning to allow the lens to read the disc then u will experience the problems that u are facing with your player.
solution: get the whole lens motor mechanism changed.
Aug 26, 2010 | LG BD370 BLU RAY PLAYER
When I try to play a disc it says BAD DISC. It won't play any disc. It make a louder noise when the disc spins than when I first bought it. We only used it 5-10 times.
the laser optical unit is most likely a little dusty, carefully blow the inside where you load the disk out with a can of air, make sure the unit is completely off while doing this. This may NOT fix it, make sure to also follow all guidelines for use of the particular can of air you choose to buy,
Jun 28, 2010 | Polaroid 7" Two-Screen Portable DVD Player
My cd player D-FJ003 says "no disc" now whenever I put any disc in. It was working fine before.
I have two of these players now and i know what this is. It is because of the disc holder. It has been pressed down to the bottom and no longer lets the motor spin the disc. The fix is to carefully pry off the small disc holder that spins and find a place where it will spin freely then apply superglue to the center of it and very carefully sliding it back on making sure its not too far down as to not play. Let the glue dry for a long time and carefully put a disc on and see if it plays. This worked with mine but i kind of broke it in other ways and didnt let the glue dry fully so its still kind of scetchy so i bought another on on ebay for like $10.
Feb 17, 2010 | Sony Walkman D-FJ003 CD Player
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
"no disc" error message
Did this problem just start? It may be due to the lens no longer reading the disc. Try a lens cleaner. If your lens went south, it usually is paired with a clicking noise or/and the combination of a no disc/disc error message. I would also recommend staying away from Polaroid dvd players and tv's in the future. They have a habit of not making parts available, especially after the warranty.
Feb 28, 2009 | Polaroid PDM-1058 Portable DVD Player
Disc wont read
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Apr 06, 2008 | Nintendo Wii Console
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Apr 26, 2006 | Durabrand 8.5'' Portable DVD Player
Philips PET702 Portable DVD Player Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
