Question about Car Audio & Video
Grundig MCD36 6 disc changer won't eject or play CDs. Erro messages are Surface or CD loading!
  • 8 Answers
SOURCE: Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
Posted on Jul 22, 2009
smarthome2
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
SOURCE: Renault cabasse auditorium 6 CD changer won't
I left it for 24 hours and tried to eject the disks again. It took a while churning itself, but eventually the 1st disk was ejected followed by the 2nd. I think it is like a slow computer. One has to be patient and it works: try to rush it and it won't.
Posted on Oct 21, 2009
franktilt
  • 403 Answers
SOURCE: '02 Ford Explorer 6 CD
Are you using Burned cd's
Posted on Jan 27, 2011
SOURCE: Ford F150 with 6 disc cd changer that is stuck
I have the exact problem as of last week when my battery and altenator died. I tried to have it fixed at ford, but they said it was broken. Did you have any luck?
Posted on Feb 08, 2011
2010 Mazda 5 CD changer not working
if you have a genuine unit it may be connected to the CPU or need resetting after the battery change.
Dec 12, 2013 | 2010 Mazda MAZDA5
Please remove the top cover and manually rotate the motor to release the loading. It can be due to a warped cd or a motor pulley which had slipped.
Also check if the linking cord to the loading motor is having a continuity.
If not there is fault in the processor controller or the loading IC.
Aug 09, 2011 | Car Audio & Video
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Jul 27, 2009 | Car Audio & Video
1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Oct 26, 2008 | 1992 Lexus Es 300
Car Audio & Video Logo
376 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
