After a lightning strike, our computer mother board, television, telephone and printer, all of which are served by Time Warner, required service. After everything has been repaired, the printer still will not power up. Everything stemmed fromthe ups failure. What can you tell me about the most likely solution to our problem? The printer is the Pixma 160.Additional info: Power cord is OK. USB cable has continuity. Unit is under warranty.
    Master:
  • 788 Answers
The company that manufactured your UPS will most likely have an insurance policy if its product fails and damages any of the connected equipment. I would contact them about this. Hopefully you have all your receipts for the UPS and printer. If for some reason or another the UPS manufacturer won't cover your printer then your next step is to contact Canon at 1-800-OK-CANON to inquire about warranty service on the printer. Don't mention the lightning, just say it stopped working all of a sudden and if it's still under warranty they will most likely replace the entire printer.
If all of this fails then your only other option is to replace the printer, this class of printer is not usually repairable or is more expensive to repair than to buy a new one.
Posted on May 26, 2008
    Sergeant:
    Champion:
  • 271 Answers
Thundering causes a high power voltage to get into any device which will deffinetly damage the power unit inside them...
Considering your problem,the printer might not be checked properly after the power unit repair inside it...(might have other circuit boards inside burned)
Printer ports might have black burned covering (no contact with each pin) try shaking the power code...
Power cord might be burned internaly
If you have the warranty go get it fast...(but the warranty is not valid for physical damages <burned up things> )...
PLEASE RATE ME ( FIXYA ).<blue boxes>.....................
  • 13,433 Answers
There might be damage inside the printer, hows the power adapter is it working or not? - that might be the problem and the printer might be fine?
Had Lightning strike. TV box destroyed and tv does not get power. Which boards may need to be changed?
The power supply board is the first board to feel the impact of a lightning strike.. Try that one out first.
Jun 21, 2016 | Televison & Video
Got hit by lightning and won't turn on. Power source is good. Need to find out how to take it apart.
Most of the time after an appliance has been hit by lightning, it is toast. In the case of a printer you can probably buy a new one for the cost of the replacement part. Next time make sure you also purchase a surge protector to plug your computer and printer into and then you will be protected from lightning strikes.
Sep 29, 2015 | HP Officejet 6700 Premium E-All-In-One...
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
I'm looking for a power supply for a sinotec 32"LCD tv. my tv was damaged by lightning
The replacement SMPS must confirm to the voltage/current sepcifications required for the TV and so it is best to get the same type from the dealer.
However if you are trying to get a universal type the output voltage and the protection should be of correct value or else it can further damage the motherboard.
finally if this was a lightnening strike please confirm if the mother board is working if not investing on a new SMPS should be reconfirmed.
Tips on SMPS repairs click ON:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 20, 2011 | Element Electronics FLX-1910 19 in. LCD...
Lightning strike near house. Power surge came through phone line and ethernet cable. lost modem, computer, time machine, house security system, and HP Officejet 6310xi. When printer is connected to power...
From your description the HP printer is damaged beyond repair, when a lightning strike occurs it also went through the power supply affecting the main board and destroying ic's and other parts. It is more than likely the interface cord from the computer to the printer also took a jolt hitting the printer from both sides finishing off any chance of recovery, you would be further ahead replacing the item.
Jul 06, 2011 | HP Office Equipment & Supplies
After lightning struck in my backyard, printer won't turn on.
HI, this was an unfortunate surge that has fried the power board Assembly in this unit. it has also fried the main control. this may be a total loss unless, you are considering replacing the entire mother board and power assembly as well.
Replacing the main control board and power board will restore proper function.
May 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Lightning strike and tv picture messed up
This unit needs to be sent or taken in to a service center for complete testing and service. The lightning strike has caused a component failure, in the main board of the television. This is the board that controls all the functions of the television. The customer service telephone number for Insignia is 1-877-467-4289. You can also go to the website www.insignia-products.com. Go to the customer support section and ask them for help getting you television evaluated and serviced. I hope this information helps you solve your problem.
May 18, 2009 | Insignia 37" LCD Flat-Panel HDTV
Compac presario 2200
There is a high probability that your laptop has been fried, especially if it was plugged into the mains at the time of the lightning strike.
A lightning strike could damage many components and even if you could get it fixed (most likely require a motherboard replacement) there are no guarentees that some other component won't fail in the future.
If it was me, I would put my money towards a new laptop and get a surge/lightning protection power board and disconnect the laptop from the main during a lightning storm.
Jan 07, 2009 | HP Compaq Presario 2200 Notebook
I have a Brother MFC 7220 - it won't print but says manual feed. Also the telephone is not working. All this was fine yesterday. The machine is about 1 year old.
Hi zoltansz
Have you tried the following
Use the telephone cord going in to machine on a regular telephone. If this works cord is fine. Plug cord back in to machine. Press the dial button on machine if you hear a dial tone check the settings for Pulse / Tone dialing (refer to manaul). If you don't here any dial tone the fax modem on the machine is faulty (posible lightning strike on telephone line. You will then have to take the machine in to a service centre.
Please feel free to uase the Repair Service Directory on this site to locate a service centre close to you.
Regards
Go-Tech
Dec 15, 2008 | Office Equipment & Supplies
61 people viewed this question
k24674
jasbo
jasbo
