Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have a F.P Intuitive Eco IW712 with a 130 error code. Called mechanic who advises that the Harness Terminal is corroded. Machine was purchased Sept 2003 and estime cost of repair is $400. Don't know whether to repair cut my losses and purchase new machine. What's your opinion. Reagards, Annabelle Anderson
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
SOURCE: Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Posted on Jun 25, 2008
SOURCE: Intuitive Eco IW811 washing machine
I have the same problem , was told that it is the RPS rotary positioning system, cost about $200 to get someone out to fix it.
Although I did reboot it and it went through the wash ok.
Posted on Sep 01, 2008
  • 34 Answers
SOURCE: service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Posted on Aug 03, 2009
  • 34 Answers
SOURCE: fisher@paykel Intuitive eco comes up with code 130
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco washing machine wont go the codes 150, 108 and 103 are showing on the digital display panel. what is wrong with it?
Not sure what model of Intuitive Eco you have? 150 and 103 are not common. 108 is a communication error between the display board (with screen and buttons) and the motor controller (the other main board). Check the plug on the harness from display to motor controller, but most likely will need one of the boards replaced. Have a look at the boards for any sign of corrosion which may give you an indication of which one is playing up.
Aug 12, 2013 | Washing Machines
Fault code 130 appears on my fisher and paykel intuitive eco washing machine, do I require a technician to fix this?
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Aug 25, 2012 | Fisher and Paykel Washing Machines
Intuitive ECO Model IW811 display error codes 240 and 130. what does this mean?
The fault codes 130 and 240 are pertaining to a Rotor Position Sensor problem. It is the part located wedged into the motor stator and it's sole function is the detection of motor functions particularly the rotor as the name suggests. The problem can be a simple loose wire harness or a damaged Rotor Position Sensor.
Unplug the machine. Tape the lid closed then lay the machine's front on a padded floor. Remove the single bolt holding the "plate-like" rotor to the shaft to access the Rotor Position Sensor. Once the rotor is off, check the contacts on the Rotor Position Sensor end of the wire harness to see if any have been damaged. Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Position Sensor harness. Consider replacing the Rotor Position Sensor if no issue is found with the harness and the connectors.
Jul 18, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing machine Intuitive Eco Error 130 then Error 136
Hi - Faults 130-136 means there are some serious comm problems - motor stalls etc. The most likely cause would be the RPS Senor - has failed or loose, corroded, bad wiring connections.
This is under the machine - tilt on its back, remove the center round rotor has magnets on the inside be careful it stays clean. there are 4 bolts in the middle - remove to get stator off with all the copper wounded contraption, remove the wiring - not to worry too much but note on the stator Y_B_R relates to colours on wire harness, note also the harness & RPS component. replace this assemble & should work fine unless the controller is a dud.
95% of the time this is your culprit.... Part # 438515P I think for these range - pays to check 1st - You need to quote the Product nuber as this is critical to the components under the hood if you get my drift.
May 31, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Eco intuitive washing machine
The rotor position sensor is faulty or corroded. You will need to remove the motor to access the RPS. It is a small electronic board that slides onto the coils of the motor.
Oct 24, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
HELP!! fisher and paykel intuitive clothes washer: error code 36
schmotty, An error code "36" means Water leak fault: The Motor Control Module has needed to top up the water level more than 4 times during agitate. This is excessive, as normally only one or two top ups are required to replace the air that has escaped from a full load during agitate. The most likely cause is that the machine is siphoning. The other alternative is that the machine has developed a leak.Thats what you have to do: Primary Source: Pump System. Action 1) Check the height of the drain hose outlet. Minimum 33.46in / 850mm, maximum 47.24in / 1200mm. 2) Check that the hose guide is fitted and check that the hose does not protrude more than .78in / 20mm beyond the guide. Secondary Source: Mechanical. Action: 1) Check the pressure tube connections on the outer basket and Motor Control Module. 2) Check that the drive shaft seal and the pump housing seal have not developed a leak. Tertiary Source: Motor Control Module. Action: Replace Motor Control Module. Gendos...post it
Jan 01, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
165 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
