Question about Lowrance GPS
Cannot get lowrance 4800m off its American factory settings
  • 1 more comment
  • jivill Oct 02, 2010
    The GPS displays an american map and co-ordinates which are north west.This is how it displays the American factory settings,I can't get it to pick up a satellite here.
    The Gps only has american maps,it is in a boat I bought,in the manual it says there is a auto satellite search in the satellite status menu but it is not on my screen.the manual is the right one for the gps.There must be an easy way to get it to pick up satellites here,I can't key any gps points into it until it finds these.
    yes
  • 13,433 Answers
I'm not sure what do you mean by its american factory setting? if you could explain a bit maybe I can assist you with it.
Thanks
Posted on Oct 02, 2010
  • 2 more comments
  • Ekse Oct 02, 2010
    Yes I suspected that might be the problem. Do you have a map of the area where you are now on the GPS? - what map does the GPS have installed on it right now, does it only have american maps currenctly? Can you for example, navigate, or move the map into europe, try finding finland, Then see if you can find Turku, If you can then find the street, Itainenpitkakatu from around the center of turku, then you definitely have more than american maps on the device.
    If you can't get out of USA, / america. Either the gps is set to use only american maps currently, or it does not have any other maps installed on the storage card?
  • Ekse Oct 02, 2010
    Built-in custom, detailed Lowrance map. Contains: enhanced detail of continental U.S. and Hawaii. Includes more than 60,000 nav aids and 10,000 wrecks/obstructions in coastal and Great Lakes waters. Metro areas, selected major streets/highways and interstate exit services details included.
    No outside US, hawaii, maps included.
  • Ekse Oct 02, 2010
    So you are in the US, on the map? Not outside of US
  • Ekse Oct 02, 2010
    page 26, satellite status page.
    On the page you have 3 pictures,
    1. no satellite signals --- 2. few satellite signals but no good signal -- 3rd image on right, notice good satellite signals from the almost full bars.
    If your status looks like the center picture, please move around, or make sure the antenna is on a good position with unblocked sky view.
I need reset instructions for a Lowrance 510c Depth Finder Only Model - No GPS
go to menu click on system click on reset to factory settings see if that helps you
Aug 19, 2013 | Lowrance Boating
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
I would like to reset to factory settings
Hi.
Only soft reset is available.
This will reset all settings to factory, but will not erase personal data.
To do soft reset boot up holding the MAP/MUSIC button and the power button at the same time. Leave buttons only when you see that the scroll bar at the bottom has finished. The iWAY will reset to default settings.
Jan 09, 2010 | Lowrance iWAY 250C GPS Receiver
Mouse SCM-4800M not work! Not Recognizes DIspositives
got run and in run type devmgmt.msc and it will open up device manager ,,once the device manger gets up then try to check the mouse ,,,make sure that it not haveing red ex on it ,,,,,,,,,,it it has then try to right click on to it and enable the serivices ,,,,,if it doesnot work then under same device manger check for usb port and look for the same ,,,,
Jul 22, 2009 | Samsung Pleomax SCM-9000 Mouse
Gps wont pick up satilites
Make sure all the connections at the back of the unit are tight. If it still doesn't respond try a new puck.
Apr 15, 2009 | Lowrance Globalmap 5300c Igps 5" Screen...
Stops on boot up
I downloaded an updated version of software from lowrance. Once i installed the software it came back working like new.
Dec 30, 2008 | Lowrance LCX-18C
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
GPS Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
