Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Where is the learn button to proramme a new remote hand piece Bob
    President:
  • 3,197 Answers
There is no learn button on a new remote hand piece. It is on the rear of the motor unit.
Posted on Oct 03, 2010
Where is the "learn" button on the garage door opener? We are trying to install a new remote opener to this 1145lm opener.
It's on the back of the motor. Press the learn then the remote button. You should hear it click and the light bulb should flash.
Feb 15, 2015 | Building Materials
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
I want to change current keypad code linear LD050 model
To change the keypad code.
Step 1:
Erase the current code - On the upper right hand corner of the left hand side of the unit, you will see a "learn" button.
Press and hold the "learn" button for 12 seconds.
When you release the learn button, the red light above the button will blink 3 times and then come on bright for 15 seconds.
When the light goes out, the memory in the operator is erased.
Step 2:
Learn a new keypad code.
Press and release the "learn" button.
The red light will come on. You now have 15 seconds to complete the next task.
Go to your keypad and enter your desired code (1 to 6 digits long)
press start/stop on the keypad.
The red light will blink when the code is successfully stored.
Don't forget to re-enter all of your hand held remotes into the memory:
Press and release the learn button. When the red light comes on, press the button on the remote you wish to update.
Repeat for other remotes. By the way, If you hold the learn button down for 10 seconds, you'll have to start over and the memory will be erased.
Nov 14, 2012 | Home Security
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    I have a chamberlain opener Model 3280. I have tried to set my three button and keypad model 976LM remotes from my old house using the learn button, but it just won't learn the remotes. I have tried...
    For your hand remotes try this:
    Press and hold the button down on the remote while you press and immediately release the learn button.
    For the keypad:
    Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
    If this doesn't work your logic board is bad.
    Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
    No learn button
    It's there, but you may have to remove the large slide switch to see it. The slide switch just pulls off. The learn button is on the right side if the face of the remote box, under the ON side of the slide switch. Make sure you place in the smaller slide switch in the REMOTE Position, before attempting to get it to learn a new code. Remember, you must push the Learn Button (use a small screwdriver or ball point pin refill) to push down on the learn button0 and press the ON button on the hand-held remote at the same time. Listen for a beep(s) and let off of both buttons after the beep(s) stop.
    Jan 10, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
    How to reprogram whisper drive garage door opener , we can close it by the outside pad but not with the 2 openers the openers check at a dealer and he said its ok, just need to reprogram it dont know how...
    1)Press and release the "learn button" on the motor unit (the indicator light should glow steady for about 30 seconds
    2)While the learn indicator light on the motor unit is glowing, press and hold the button on the remote unit you are using to open the door
    3)When the motor unit's light starts to blink, release the button on the hand held remote. The motor unit has now learned the new code.
    I hope this works for you!
    Feb 12, 2010 | Liftmaster, Chamberlain, Sears Door...
    HomeLink works in vehicle... unable to program hand held or remot
    When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
    Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Learning remote codes for my harmon kardon avr354
    a) Place the two remotes so that their IR transmitters face each other
    end to end, separated by about one inch. The
    AVR 354 remote’s transmitter also serves as an IR receiver during
    the learning process.– AVR 354 and Original Remote Head-to-Head
    b) Press the Source Selector for the device mode you wish to learn
    a code into, and place the AVR 354 remote in Learning mode by
    pressing and holding the Learn Button until the Source Selector lights
    up, then release.
    Learning Remote Commands
    c) Press the button on the AVR 350 remote you wish to program with
    the new code, and the Source Selector will flash once. You may
    learn a new code into the following buttons: Device Power On/Off,
    Alphanumeric Keys, Last Button, Back/Exit Button, Menu Button, Navigation Buttons, OK Button, Disc Menu Button,
    the four Teletext Buttons, Channel Up/Down, Volume Up/Down,
    Mute and the Transport Controls (including Record).
    d) Press and hold the button on the device’s original remote whose
    code you wish to “learn” until the Source Selector flashes three
    times, then release.
    e) You may program additional buttons by repeating steps c) and d).
    Press the Learn Button once to exit Learning mode, or wait for the
    remote to “time out” and exit Learning mode on its own after about
    30 seconds.
    Dec 11, 2008 | Harman Kardon Harmon Kardon SoundStick II...
    Craftman garge door opener changing code on key pad
    having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
    Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    29 people viewed this question
    Top Sears Building Materials Experts
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
