Question about RCA F36689 36" TV
T V was on when Power company switched off the breakers and all power to my house they were replacing the power ploe when they hadcompleted the job and switched the breakers back on my tv would not turn on I tried switching outlets and unplugging it for 10 minuts but it still will not turn on
  • 130 Answers
Hi
power suply blew up probably cause by over currant ,minor repair dough. You got to see your friendly repair guy and send the bill to power company
Posted on Oct 02, 2010
I shut the power off to a smart meter that was on a house I was remodeling. When I restored power to the meter the power in the house stayed off why
Two things jump to mind.
The contractors turned of the main breaker in the fuse box.
The utility company doesn't have you registered with them and they have stopped power after the last occupants left. When you turned the power off the utility company saw there was no demand so the place was empty.
Jan 27, 2016 | Computers & Internet
Trips breaker
tripping breaker indicates over load or dead short
it could be from failed start /run capacitors on the compressor unit ( (most likely)or from vermin across the power board
I suggest that you have a technician inspect and quote on repairs
Jul 18, 2015 | Heating & Cooling
Panasonic Home Theater System ....No power
Likely a power surge hit your house while away. This happens when power turns back on or lightning hits close to your house. If insured, call insurance company about it. You may be covered for replacement or have deductible applied. Small appliances like this are most susceptible to power surge. There is not enough protection designed in.. The best protection is surge module on main breaker panel or buy a protected power strip to protect high value electronics.
Apr 16, 2014 | Panasonic Audio Players & Recorders
Last night, the breaker tripped and we have lost power to the stove, hot water heater and the washer. We reset the breaker however, it dosnt seem like it is pushing enough power out for the stove, hot...
That means you have only one live wire running the whole house. If this happens the power sneaks through a 220 volt appliance and feeds the other half of the house but at reduced power (a brown out) This may damage appliances. Reset the main to the house. If it still isn't fixed call the electric company in your region to fix the wires feeding your house
Nov 26, 2013 | General Electric Electrical Supplies
I have a speed queen sc35md2yu40001washer that keeps blowing the 2amp fuse as soon as I switch on the breaker it is the fuse where the incoming power goes through before it goes to the transformer
Good job tracing the location of the fuses. Now, logically, the transformer is the next thing to check. When power is turned off at the house breaker, remove one of the wires on the output side of the transformer and see what happens when you turn the power back on. If the fuse blows, the transformer is shot and needs to be replaced. If not, go to the next device on the circuit, etc...
Jan 16, 2013 | Washing Machines
200 amp breaker is melting and power is flickering in house
Usually this is a defective breaker, possibly caused by water intrusion into the panel. This is NOT a do it yourselfer job -- refer this to a professional who knows what they're doing. The meter base needs to be pulled to cut the power to repair it and you are dealing with power that has virtually no fuse or breaker protecting it. If that sounds dangerous, there's a good reason -- it is. I get unnerved doing these. I hope I've helped you, though maybe not the answer you were hoping for.
Feb 14, 2011 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
My hotpoint washer does not turn on
There are four components to check if your washer will not turn on at all. You need to check your power supply, the door switch, the cycle selector switch and the timer motor.
Am suspecting the power supply, Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
That should do the job for you. Hope this helped you.
Jan 14, 2011 | Hotpoint Dishwashers
All radioes in my home have a loud buzz. started buzzing two days ago. have not plugged in anything different.
I assume this is on AM as FM would typically not do this.
You have a noise generator interfering someplace. I suggest you use a battery operated radio and tune to the buzzing.
Then turn off your main breaker to your house. If the buzzing remains, the problem is external to your house. It MIGHT be a bad insulator on a power pole. See if your electric company will investigate this.
IF the noise totally went away when you killed the power to your house, turn off ALL the breakers then turn on the main and one by one turn the brealers on till the buzzing returns. When it does, analyze what is on that breaker.
Some common in house sources: Bad door bell transformer, ionizer or electrostaic air cleaner, flourescent lights and CFL bulbs, Bad connections in wiring (very dangerous), switching power supplies and "wall wart" adapters to name a few.
Mar 13, 2010 | Motorola Spirit HP 2-Way Radio
Dyson upright will not power up
As was my problem, checked and washed filters (both) checked all accessable tubes but problem was that the tube inside the drum and the tapered section at the top ws solid with dust.
remove 3 small screws in top (Torx heads) and clean out. Job Done!
May 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
125 MAIN CIRCUIT BREAKER REPLACEMENT
I dont mean this to sound arrogant. but if you have to ask you might be best to have a professional to do it. the wires coming into the box will be hot without being able to pull meter off of house to disconnect. the panel has to come off and many are different
Sep 25, 2008 | Gb Electrical 100 Amp GE Load Center
RCA F36689 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
