Question about Samsung Cell Phones
I changed debug settings now phone is not working
Hi
haw to
samsung soft instoleshn
Posted on Oct 02, 2010
How do i enable usb debugging on my lg306g
Settings > About Phone > tap Build Number 7 times.
Settings > Developer Options > USB Debugging
Voila
Oct 17, 2016 | LG Cell Phones
Had system apk data erased on Android phone huawei y536a1 how do I replace it phone acting up
) For Android 2.3 or earlier: Enter "Settings" < "Applications" < "Development" < "USB debugging"
2) For Android 3.0 to 4.1: Enter "Settings" < "Developer options" < "USB debugging"
3) For Android 4.2 or newer: Enter "Settings" < "About Phone" < Tap "Build number" for several times until getting a note "You are under developer mode" < Back to "Settings" < "Developer options" < "USB debuggin
Feb 26, 2016 | Huawei Cell Phones
Micromax canvas a 101 pattern lock open
How to Unlock Micromax Phone Using Hard Reset Using stock recovery and wipe data. This method will result In a full factory reset of your phone . How to do this?
  1. Switch off, Pull battery.
  2. Insert battery and Press and Hold Power+Volume up+Volume down together (different phones might have a little different method of booting into recovery mode, but this is the most general one).
  3. You will then boot into recovery mode , use volume keys to navigate up and down and power key to choose.
  4. Choose Wipe DATA
  5. Choose wipe cache.
  6. Reboot device.
You are done and your lockscreen is gone and phone has been hard reset. Please not this leads to permanent removal of data.
Unlock Micromax Android Phone using Android Debug Bridge In this we will use ADB (Android Debug Bridge) to unlock the device without losing any data.
  1. First we need to set up ADB on device , you generally need these link of adbzip in the bottom or you can Google on how to install ADB in windows.
  2. Just make a folder adb in c/root and copy the files.
  3. Install drivers of your phone (Use PDAnet if you have problem with finding drivers).
  4. Turn on USB debugging on phone. Follow : Setting->Development->USB Debugging (Turn On)
  5. Open Command prompt in computer , and type cd C:/Android (Android here is the folder where my adb files are , change according to yours)
  6. Then you can try following sets of command
Adb files rar download 2shared
Jan 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
How to turn on usb debugging by using a PC
Im finding no way around it. To open the service menu a code typically needs to be inputted into your dialpad. Sorry, sounds like getting the screen fixed may be your only way.
Feb 17, 2014 | Samsung Cell Phones
Were can find usb debugging on sony c902
Go to "Settings"
"About phone"
repeatedly press "build number" (about 10 times) After enough presses you will get a toast notification that says "You are a developer"
Back up to settings and now you will see the developer menu.
USB debugging is located in the developer menu.
Dec 23, 2013 | Sony Ericsson Cell Phones
How to Restore Factory Settings N99i
Shortcuts for phone settings
Change languge: *#0044# + dial for English
Check Version: *#8375#
Firmware verion: *#8882#
Test*#87#
Debug*#8899# (?)
IMEI number:*#06#
Restore factory setting:*#66*#
Factory settings:*#3646633#
auto test:*#87#
Password for restore factory settings: 1122
Nov 11, 2008 | Dual Electronics N99i Cellular Phone
Razr V3 audio will only work on speaker phone
If you quickly enther ##debug (##33284). if the 4 doesn't appear then that means the phone regognized the code. press END then once you see you home screen press CLR and then the LEFT SOFT key which brings you into the debug mode. ONce your in there be very carful not to change any settings for it can easily screw up your phone so be cautious. to go through the pages press the LEFT or RIGHT SOFT keys. more prefferd by pressing the RIGHT one. press it a few times till you come to the page where the first line says "ServOPT: NoChg". The second line or the line right after that says "AudioOpt: Auto". Scroll down to it by pressing the down button on your keypad then once the little pointer on the left of the screen is at "AudioOPT:". you'll notice that right on top of the RIGHT SOFT key says change. Pess that till it goes from "Auto" to "Spkr". once your finished all that press Exit (LEFT SOFT KEY) and you will see it going out of the editing mood. Press CLR and the LEFT SOFT key on the keypad again to Exit the debug mode. Once you out to the main screen again press ##debug again to disactivate the Debug mode. Again if the 4 doesn't appear then that means the code registered and it disactivated. If you won't disactivate it it will enter into the mode again by switching your phone off and on again. which you don't want to happen. however if it does happen press the CLR and LEFT SOFT key then you out again. then disactivate it again by pressing ##debug.
If that doesn't solve your problem then i'm sorry but i can't help you. I am also not responsible if you Screw up your Phone.
This only works on the Razr phones so don't try it on other phones.
Sep 03, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
