I am using Windows 7 HP. Suddenly I can no longer access a partition on my disk drive 0.On the computer display "Video2" does not have a bar code any longer; yet an other partition on the same drive called "Premiere" is ok. When I go to Computer Management, Video2 is there with 49% free space Could it be Hidden? How do I "unhide it? Good luck, Rick Nauta
  • nauta1 Oct 02, 2010
    There is NO virus involved, I am aware that is always your first answer; anyhow I cannot copy the data because I cannot get hold of them since I cannot access the partition. The unhide idea was just a red herring since explorer will not display the data.
    Programs like Acronis Disk manager and Spotmau show the partition as normal. I think that the index or boot or whatever organises the data needs repairing, but how to go about it I do not know! Can you point me in the right direction?
    Rick Nauta
  • nauta1 Oct 03, 2010
    After unsuccessfully trying out Acronis Disk Manager, Spotmau and Paragon Hard Disk Manager, I had the feeling that is was a security matter! After some research I added "Authenticated Users" to users which had permission and BINGO, problem solved!
    May I suggest you remember this as an experience for future use.
    Regards, Rick Nauta
    President:
  • 1,216 Answers
Your partition ia infected by a virus.
do 1 thing.
open that partition from address bar , or right click on that partition and select explore.it will open up.
now copy and paste this data to another location.
next format this infected partition.
after format is complete you can paste your data here and there will be no problems now.
talking about your other problem.
Following is the process to unlide
1.Above the address bar click tools->folder options.
2.under view check show hidden files and folders , click apply.
If you have some important data hidden , perform this step before copying
Posted on Oct 02, 2010
  • Aviral Saxena
    Aviral Saxena Oct 02, 2010
    if you suspect such a case you should try a windows repair by inserting a windows cd or system restore if restore point is set.
    i advised you to
    did you do that?normally in such cases partitions can be accessed from address bar or by clicking explore.if this does not do the trick repair windows option is always available and you may try it
  • Aviral Saxena
    Aviral Saxena Oct 03, 2010
    Thanks , i have added another piece of information to my knowledge.
    As your problem is solved now you can give me some credit by accepting the solution if you feel i was helpful to you.
    anyways , Thanks for reply , thanks a lot .
Is it possible to upgrade windows XP to windows 7
If you are asking could you upgrade directly from Windowx XP to Windows 7 as a direct upgrade, the answer is yes but it's not recommended.
The much better method is to use Windows Easy Transfer to move your important files from your computer onto an external hard drive. After all your files are backed up safely, it's best to start the Windows 7 install and when you get to the "Upgrade" or "Custom (advanced)" screen to choose Custom. This will open up the drive view. Click on "Drive options (advanced)" which will bring up the ability to delete the partitions.
If you find that you have more than one shaded area in the Drive 0 bar, you have more than one partition. Unless you have experience creating and modifying partitions, only delete the partitions on Disc 0 which are marked Drive (C:). Otherwise, you can decide what partitions you need to delete to make enough room for Windows 7.
I'm not sure if you've already done your homework or not but before you upgrade to Windows 7, run the update advisor to ensure your system and software is Windows 7 ready and make sure to collect the hardware drivers that work with the exact version of Windows 7 you are installing... 32 bit and 64 bit are totally different monsters!!!
Having all of your software install disks on hand, and all your backups (and a bootable copy of the backup software!!) and Windows 7 hardware drivers on an external hard drive is the best way to approach an upgrade.
Best of luck!! Hope this helps.
Mar 22, 2014 | Acer Aspire Computers & Internet
Expand disk partiton of windows 7 system volume
Go to "Start" and click in the search bar. Type, "disk format". Click on create and format disk partitions. This will display all drives detected by Windows. It will also allow you to delete, create, and resize partitions.
This tool can also be found by going to Control Panel > System & Security > Administrative Tools > Computer Management. When the tool opens Click on Disk Management under Storage.
Mar 11, 2014 | Computers & Internet
Trying to install windows 7 retail 64 bit on Scorpio (was installed once already started getting wonky so decided to format reinstall) boot with usb dvd rom drive get to unpacking of windows files and...
According to Microsoft, Windows 7 must be installed on a primary partition. This error code means the installer hasn't found a primary partition on the target drive. The primary partition must be on the first hard drive in the boot order, and if you have more than one user partition (not counting the small drive table partition), you must install to the first user partition. Unfortunately MS doesn't seem to have a clear, comprehensive answer to the issue. I've gleaned the following from various forum responses.
For some reason the installer is date sensitive, so make sure the time and date are correct in the BIOS. Time your next install attempt so it will NOT go past midnight during the installation.
Check your BIOS settings to make sure the drive is listed as a "primary" drive (drive 0, not drive 1) rather than a secondary.
Some people have had problems with the Windows 7 installer on drives that have the Master Boot Record from previous installations. Try a FORMAT /MBR using the Windows 7 install CD. If this doesn't work,
  1. Use the partition command to remove the target partition from the drive to wipe this out
  2. Partition the now unused space and reformat (again!), and
  3. If the partition command or installer has an option to set a partition as primary (or something else), choose primary (disk 0) for the partition you want to use for Windows 7.
If all else fails, use your HP Software Recovery CD to do a complete repartition and reformat. You could use the Windows 7 partition command to do the same thing, but then you would lose the HP System Recovery partition. However, if HP is marking the System Recovery partition as partition 0, it could be causing the problem. In that case, see if HP has an updated version of the CD that includes a fix for this, or do without it and turn it all over to Windows 7.
Dec 26, 2010 | Western Digital WD Scorpio Black...
My drive is brand new, unused, when I click on the Start button, then Computer, I see the newly attached iomega drive as a CD Drive. so far so good. But when I RIGHT click on the iomega drive, chose...
As long as it is just the USB 3.0 and not the USB 3.0 with encryption. You will just need to format your drive.
Windows 7 / Vista 1. Connect the Iomega Hard Drive to the USB on the computer. 2. Next, open Disk Management. (Right click on the Computer icon > select Manage > click Storage > select Disk Management ) 3. You will see a prompt indicating you must initialize a disk before Logical Disk Manager can access it. The disk will be selected by default. Read the note at the bottom of the window and select the partition style you want to use. 4. Click OK. 5. The drive will now appear as Unallocated and the bar will be black. Right click on the black bar and select New Simple Volume. 6. When the New Simple Volume Wizard opens, click Next. 7. It is recommended to leave the maximum disk space selected. Click Next. 8. Assign the next drive letter available. (It is recommended that physical drives are placed before mapped network drives.) Click Next. 9. Windows will automatically select NTFS as the volume format. This is the preferred file system for use with Windows 7, Vista, and XP. 10. Select the option for Perform a quick format, enter a volume label if desired, and click Next, then click Finish. The drive will be ready to use when the format completes.
Windows XP / 2000 1. Connect the Iomega Hard Drive to the USB on the computer. 2. Next, open Windows Disk Management. (Right click on My Computer > select Manage > click on Disk Management ) 3. If the Disk Wizard opens, click Next. Select the disk, click Next, then Finish. If the Wizard does not open, locate the drive in the lower list. Look for a disk that does not show a drive letter or file system. CAUTION! Make sure you select the correct drive before proceeding. The following steps will erase all information from the selected drive. 4. Right click on the drive name and select Initialize Disk (Windows XP) or Write Signature (Windows 2000), then click OK. NOTE: If the options listed above are not available, you might need to delete the primary partition. 5. The drive will now appear as Unallocated and the bar will be black. Right click on the black bar and select New Partition (Windows XP) or Create Partition (Windows 2000). 6. When the Create Partition Wizard opens, click Next. 7. Verify that the partition type is Primary partition and click Next. 8. It is recommended to leave the maximum disk space selected. Click Next. 9. Assign the next drive letter available. (It is recommended that physical drives are placed before mapped network drives.) Click Next. 10. Select the option for Perform a quick format, click Next, then click Finish.
Nov 25, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have an HP 513n, currently running Windows XP Pro. I'd like to install a second internal hard drive, install Windows 7 on the second drive, and then have the option of booting from the first drive under...
Yes,
It is possible its called Dual boot option.
Step 1: Create/Obtain an Installation Disc Yes, we’re all aware most motherboards these days allow you to boot from a USB flash drive, but setting that up is a guide in itself. We’re going to assume that you either already have a Windows 7 DVD, or have an ISO file. If the former is true, feel free to skip ahead to Step 2.
To create a Windows 7 disc, pop a blank DVD into your burner, and burn it as an image file with any of the countless apps that can handle ISOs. Our personal favorite is ImgBurn, but to name some others: Burn4Free CD and DVD, CDBurnerXP and Ashampoo Burning Studio Free.
Step 2: Create a New Partition Editor’s note: Before continuing I’d like to take a moment to acknowledge the fact that data corruption is a possibility. Even though this guide is absolutely harmless, random software anomalies can and do occur – do yourself a favor and backup your precious data before proceeding. Moving on to more pressing matters, we will need to create unallocated disk space by resizing an existing partition in your current hard drive, and then create a new partition on that free space for Windows 7 to run on. Most of you who are reading this will probably only have one existing partition, dedicated to the operating system you’re currently using.
With that in mind, to help you in the process of creating a new partition we’ll be looking at two separate approaches. While Windows Vista has built-in utilities to resize active partitions, XP does not, and thus we must resort to using a third party application (GParted).
Create a New Partition on Windows VistaIf you are currently running Windows Vista as your primary operating system, we can use its built-in tools to modify your hard drive partitions. You can also use a third-party tool called GParted, which we are recommending to Windows XP users (see below). You can skip to the XP section and follow the exact same directions if you prefer the GParted route for any reason. On Windows Vista, click Start and enter “diskmgmt.msc” into the search bar. A window titled “Disk Management” should open displaying basic information about the drives attached to your PC.
Right click the partition on “Disk 0” and select “Shrink Volume”.
diskmgmt-1p.png This should present you with drive capacity information as well as the option to enter an amount you'd like to “shrink” your partition by. The recommended minimum partition size for Windows 7 is 16GB, so enter a figure of that size or larger and then hit “Shrink”.
diskmgmt-2.png You should now see unallocated space on your hard drive in the capacity you specified, situated just after your now resized original partition.
Before creating a new partition and assigning a letter to it, be a perfectionist and reassign your optical drives to the next letter down from what they are now, so that your new empty partition can have whatever letter follows your first partition (probably “D”).
Right click the newly unallocated space and select “New Simple Volume...” which ought to open a wizard screen.
diskmgmt-5p.png On your way through the wizard you'll be asked to define the capacity for your new volume to be; let it occupy the entire size of the unallocated space you've created, assign it the letter that you've just freed, quick format the volume using the NTFS file system and default allocation unit size (volume label can be anything, just name it Windows 7).
diskmgmt-6p.png You should now see a healthy primary partition with the capacity and label previously defined replace the unallocated space. With that, you can move on to Step 3.
Jan 29, 2010 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Cannot access hard drive, USB port detects it, but does not access
You can verify what drive has been detected by your Operating System, which I assume is Windows of some sort by going to: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions.
I order to use any partitions in your new drive, you will need to assign a drive letter to each new partition.
If you have a brand new drive that is completely unformatted, then you will need, also via the context menu, Create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions.
Hope it helps: let me know how you go!
Below is example of Disk Management display showing my external USB 300GB drive with _EXT disks & displayed context menu:
Jan 02, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I hit F8, here is the new error message
If this is all you are seeing, then this is not an error. What is happening here is that your computer is loading Safe Mode. This is a way to load Windows operating system without any extra software or programs, using the most basic drivers and software to load. There are a lot of benefits to accessing this mode, especially if you installed a program that stops you from getting into Normal Mode, or you have a virus that does the same. It makes it easy to troubleshoot. Here is a link to a website with a little more info:
http://www.computerhope.com/jargon/s/safemode.htm
If you load your computer normally by not pressing any keys, then you should be fine.
Mar 27, 2009 | HP Pavilion xt938 PC Desktop
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Error on windows load
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
David Payne
David Payne
