Question about Jenn-Air JS42CSFXDA Side by Side Refrigerator
Original unit bought in 2003. In early 2005 it started heating. The motherboard and condenser were replaced, but eventually Jenn-Air gave me a new unit. Tonite it simply stopped. One minute on, the next off. No lights, no sounds, no nothing. There is power in the outlet and I have checked the breaker which is fine. The unit is just dead after 5 years. Can anyone help?
HVACRH20
  • 237 Answers
SOURCE: refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Posted on Jan 02, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: JENN AIR MICROWAVE FUSE (JENN AIR MODEL M167)
The fuse holder may be loose.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and should be replaced.
Simply squeezing its terminals together with pliers is not really a good solution.
When a connection is loose, heat results, which eventually melts the fuse internally.
This is usually evidenced by a very tiny ball of solder at the point where the end cap meets the body of the fuse.
You can use a generic holder - it's a lot cheaper than ordering one. The connectors should be 1/4" tabs and it should be rated at 20 amps or better.
You should be able to get one from a home center or local appliance parts store.
If it's not loose, then it may be a failing magnetron or high voltage transformer pulling too much current.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
SOURCE: Jenn-air JRSD 226 side by side Fridge
Check to see if there is frost on the rear wall o f the freezer wall. If so, the units cooling coils (behind the frost) may be covered with ice. Defrosting is necessary. The refrigerator may not be defrosting at regular intervals a required. Standing open for a couple of days should defrost it but it will still be necessary to find out why it frosted over. There is a defrost control that automatically melts ice from the cooling coils on a regular basis. Maybe this control is not functioning.
Posted on Sep 01, 2008
SOURCE: Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Posted on Oct 03, 2008
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Posted on May 19, 2009
How do you clean sealed condenser coils
hi.ummmm.sealed condenser unit.(new one).well condenser units have to be open somewhere to cool it.1- by air 2- by fan 3-by the refrigerator cooling.(condenser inside insulation,not accessible)i suppose if access is difficult then a blast of compressed air,blast with refrigerant gas,or try for a quick fix computer cleaner comp/air.good luck.Ali
Jun 25, 2012 | Jenn-Air Refrigerators
Fridge warm. Freezer frosting over. I've
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer ( evaporator) fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
There can be many factors for the no cooling factor: the condenser coils could be blocked with dust, the condenser fan could be bad or stuck, the freezer fan could be stuck or bed, the freezer coils could be blocked with frost because the self-defrost system is not working or the compressor is not running because of a bad relay etc.
Please check this link to get a detailed idea about your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 07, 2011 | Jenn-Air Jenn Air Side-By-Side...
Arcoaire heating/air conditioner continually cycles condensation
a possible solution is to install an air dryer in line with this tube
Jan 03, 2010 | Calvin Klein The Field Controls Company...
Air conditioner shuts off early.
Hi, thermostats is not problem , it's asking for cooling when it should, it's your condensing unit outside, if mechanics said, system is o/k. then it's location of condensing unit, check location of your condensing unit, in relation to direct sunlight, condensing unit best location is always a cool place, preferable away from direct sunlight, check to see, when unit is doing that, if it's expose to direct sunlight, that could be your problem, direct sunlight for long periods could cause the high pressure & temp. controls malfunction. or maybe system is not fully charge with freon, double check freon charge. if direct sunlight is your problem, build a shade or change location of condensing unit, good luck.
Aug 02, 2009 | Ruud UAKA060 Air Conditioner
Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
Jan 25, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air 48" Built In Not Cooling
the company that replaced the parts also should have changed the low side line and capiliary line it comes together as one unit
the capiliary line is partialy restricted
May 15, 2008 | Jenn-Air JS48SEFXDA Stainless Steel Side...
Apr 10, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn Air model S176W
Heat and moisture (steam) kills the electronics in any control. but if the mark are on a circuit then there was a short in a circuit. I would check the series if your stove( first two numbers in the serial number)if it is a early series. for sure that they have make improvements in the control. And a Replacement controls will have all the improvement and revisions. good luck and let me know what you do..kraztech
Sep 07, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JS42CSFXDA Side by Side Refrigerator Logo
22 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
