Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery front-load washer won't spin or agitate
  • 2,272 Answers
The bearings in your tub/ drum assembly are most likely failing. Sometimes, the basket & support spider can also break as well. Both of these problems are evidently very common on this particular washer model made by Frigidaire.
The other possibility can be faulty motor or the motor speed control board.It has to be checked and replace
Most probably its a problem of spin control board.On the speed control board there is a inline fuse,that fuse gets short so the speed control board has to be opened.But if the fuse and speed control board both look fine then its the faulty timer.
Now to check the parts you can follow this procedure:---
1. Set the timer to the start of the heavy wash cycle.
2. Allow the washer to operate for 3 minutes.
3. Then measure the voltage drop between pin 5 of the ten pin plug on the speed control board and pin 5 of the six pin plug on the speed control board.
120volts = Defective speed control board.
0 volts= Defective timer.
The cost of speed control board is near to $250 and cost of timer is near to $70.
You can get required parts from:---
www.searspartsdirect.com or from
www.repairclinic.com:----
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 02, 2010
  • 58 Answers
SOURCE: washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Posted on Mar 09, 2010
ezed51
  • 7 Answers
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
Posted on Jun 01, 2008
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
How can I use jumpers to test 131763202 Frigidaire door lock switch on washer? Won't agitate or spin.
Hi slogjlog - Often when a unit does not spin or agitate, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Nov 18, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
1,074 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
