Question about Whirlpool Refrigerators
Freezer is fine. Fridge not cooling and water leaking at inside base of fridge
  • Anonymous Mar 11, 2014
    fagor washing machine f-4814 shows lock on display screen h014
    President:
  • 1,796 Answers
Hi!! Check the freezer fan, it should be blowing plenty cold air to both the freezer and the refrigerator, feel the fridge vents, if no or too little cold air is coming thru, turn temp. controls off and unplug unit form wall outlet and remove the freezer back panel to get behind the fan, check for frozen evaporator coil and ice obstructed air duct to fridge. Use a hair dryer to melt all the ice and when done re-assemble back panel and plug unit back into wall outlet, turn unit on setting the controls half way, I believe # 5
The water leak is probably due to the drain pipe being frozen, make sure you defrost it together with the coli and the air ducts. . click on this link to see a video on how to perform his task, the fridge type may not be the same, but the procedure is http://www.youtube.com/watch?v=NURxNRICwws&feature=fvsr This video is on how to stop water leaks. http://www.youtube.com/watch?v=3oXIUjPpnFI&feature=related
Posted on Oct 02, 2010
Freezer was working but there was no cooling in the rest of the Fridge.Technicians refilled Gas and also replaced Thermostat.While compressor on,there was a thick ice deposition on the return pipe of the...
You got suckered by the sounds of it.... if your freezer is working your fridge is fine as far as gas charge goes.... thermostat MAY have been faulty but I doubt it.... Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Electrolux Refrigerators
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
My fridge is leaking water from the inside. Top of the fridge from a part that looks L shaped.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Whirlpool Refrigerators
My fridge is leaking water in the fridge then doesnt stay cold. Freezer is working fine just not fridge.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 28, 2010 | Samsung Refrigerators
The fridge and freezer are both working normally. However, water is leaking out of the freezer compartment. We have checked the hose that feeds the water supply to the ice dispenser and it looks fine. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Maytag Refrigerators
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Refrigerators Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
