Question about Toshiba Satellite A205S4567 Notebook
I can't install Toshiba satellite A205-S4567 operating system
mellomania
  • 121 Answers
SOURCE: installation
insert xp bootable cd
hit delete or F2 to enter setup while starting computer
select boot priority or first boot device as "cd rom"
exit saving changes.
boot only 1 time from cd and then follow the installation wizard steps.
Posted on Nov 16, 2007
SOURCE: Tosiba Satellite A205-S4577
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
go here pick your model number / operating system. download / save to desktop and install. note vista users right click and run as administrator. and then
1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select USB Video Device from the list, and click Next.
7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close.
8. Restart Windows.
this bug is tricky good luck
Posted on Feb 19, 2008
  • 106 Answers
SOURCE: Toshiba Satellite A205-S4777 Camera help
sounds like the camera wires are broken. you would have to take apart the screen portion of the laptop to see if it is connected still. you would then have to splice the wires together if they are broken/damaged
Posted on May 23, 2008
Rick60639
  • 29 Answers
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
zohail
  • 1223 Answers
SOURCE: Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
pls let me know if i can help u more
and rate me FIXYA if i have fixed ur problem
Posted on Mar 03, 2009
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Toshiba satelite A205-S5847drivers windows 7 ultimate
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 27, 2012 | Toshiba Satellite A205-S4607 Notebook PC
I need Windowa XP Drivers for Toshiba Satellite A205-S5809 PC Notebook
Click Here and on the new page, click "All Operating Systems", select "Windows XP" and download the drivers one after another.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 07, 2011 | Toshiba Satellite A205-S5809 Notebook
My Toshiba Satellite keeps freezing. The laptop is a a205 5800 series laptop
Your operating system is corrupted, this can happen due to many reasons (ex:- bad installation). you need a repair operating system
Dec 16, 2010 | Toshiba Satellite A205-S5804 PC Notebook
My toshiba satellite a205-5804 has a problem with the main board, when its plug in it freezes but when not , when is used whith the battery it works alright. a repair center told me is the main board, but...
Are you using the original charger or a universal replacement? As loose fitting power plug can cause this problem but so can a loose connection at the power jack (repairable) or a cracked trace on the main board from stress at the power jack (not usually repairable - ie needs a new board). JC
Nov 17, 2009 | Toshiba Satellite A135-S2276 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Wireless
what operating system are you using?
Apr 06, 2008 | Toshiba Satellite A205-S5804 Notebook
Toshiba Satellite A205S4567 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
